Old 01-19-2016, 07:54 PM   #19 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Originally Posted by seifrob View Post
Very nice! Did you use SG as the mould or did you use another technique? Would you mind to share the knowledge?
here's my install on my 2013 Subaru WRX Sti
1) tape up the scangauge using painters tape
2) tape up the gague cluster shroud using painters tape
3) apply fiber glass resin
4) apply fiber glass (2-3 layers)
5) let dry
6) remove the hardened fiber glass
7) remove the scangauge
8) trim, sand, paint
9) i used double sided duct tape to attach the fiberglass to the gauge cluster shroud. It has held up for 2 years in So. Cal heat.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following 3 Users Say Thank You to jedi_sol For This Useful Post:
Andrei_ierdnA (01-24-2016), Joggernot (01-20-2016), mcrews (01-20-2016)
