Old 06-02-2016, 08:10 PM   #18 (permalink)
oil pan 4
Thick fuel will ruin that type of injector system. Doesn't matter how clean it is.
The powerstroke.com guy knows everything about what causes and prevents all kinds of problems the 7.3 and 6.0l engines.
Newer common rail also can take the thicker fuel.
What the people who run waste vegetable oils won't tell you is how that sends thousands of diesels to the junk yard every year. The only injection systems that can handle vegetable oils are rotory injection and medium pressure plunger type and unit injectors like found on old Detroits. All of which are mechanical diesel injection systems.
