Old 05-19-2018, 12:36 AM   #16 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I gotta agree with Metro. If it is running like you say, it ain't dead like you thought. Those zero compression numbers are not correct. You may save this car yet. Do some careful testing, starting with a retest of the compression, placing the gauge where you can see it from the driver seat. Also, the combustion gasses in the coolant tester, a so called block tester. Right now you are partially guessing what is wrong. Testing is better. Just my humble opinion.
