Old 05-30-2018, 11:27 AM   #59 (permalink)
oil pan 4
The new stuff appears to be making white light at around 300 lumens per watt.
Using cheap power supplies that might roughly double the current efficiency standard.
I saw that the local lowes was totally changing over there entire LED lighting isle. I thought the new tech was out.
Nope, as far as I can tell they changed vendors and went with cheaper even less efficient junk.
