Old 09-10-2018, 11:11 PM   #98 (permalink)
oil pan 4
I got a surprise thunderstorm last night and my 16amp 240v duosida charger got wet before I could run out side and pull the j1772 and drag the whole thing inside.
The amber fault light was on.
I was able to open it up and dry it off and it's working fine again.
You have to keep your EVSE brick dry, I could have probably put it up under the hood.
Normally the EVSE brick is up under the porch over hang or inside the garage but not last night.
