Old 10-11-2020, 04:21 PM   #8 (permalink)
oil pan 4
Normal locked rotor torque is usually around 2 to 2.5 times rated torque, but motors don't really like that. What the motor is attached to really might not like that.
Then with synchronous motors like the leaf has locked rotor torque could be even higher if you can supply the juice with out smoking a stator or armature winding.
