Aerohead. I was told you only ever advise people to use your template. You are blowing my mind. It's almost like someone is trying to spread misinformation on this site. You should really advise people that ten surface pressure readings will suffice to establish whether a mod has lowered drag. That's where the real money is.
Disclaimer: This post is meant to be humorous, however, it will probably fail at it's stated goal. If you have no sense of humour please disregard.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
