Originally Posted by Christ
Imagine for a minute that you have a piece of steel, that weighs in at 2 tons.
You have only yourself to move it, and you stand between the steel and and immobile wall (exaggeration for purposes of explanation).
On the wall is a magnet that has force equal to 1.99 tons of pressure application, and it's facing the opposite polarity of the piece of steel in front of you.. that means that the .01 tons of force you would need to apply to move the 2 ton piece of steel has essentially created more energy than you've applied. The key there, is that now there is a 2ton object moving before you, and YOU have applied .01 tons of force.
That seems to me to be pretty obviously the magnet's doing, unless you have some other way to explain it.
I understand what your saying. But I guess when were talking about continuing to generate power what resets the example? Seems to me you can generate power until the point at which you have a giant piece of steel on the wall. At which point you would need 1.99 tons of force to pull the steel off the wall right? Just to put it back where you found it in the first place.
I look at that example and think battery. Charging the battery pulls the steel off the wall and away from the magnet at which point it resets allowing you to push it back.
