Old 06-11-2008, 11:45 PM   #81 (permalink)
penny pincher
kevlar's Avatar
lucky - '92 Toyota pickup plain
90 day: 32.08 mpg (US)
Your results can never be accurate because of the fact that you did not fill up at the same station twice. That is why acetone is so difficult to nail down. There's just too many variables in the gas station tanks and where the fuel is processed from. I've been playing with the stuff about two years now and always, always get varied results. I filled up one time at a shell in a different town, spiked the gas and actually LOST 2 MPG's! I do, however, believe that your driving habits greatly influenced your mileage over your buddies. BTW, I admire your vigilance in getting some logged results! If you refer to page one of this thread, you'll see my history of tests.
Every dollar I save, .....I save!
half exposed Lucky http://ecomodder.com/forum/attachmen...1&d=1210727433
how it was done...
http://ecomodder.com/forum/showthrea...html#post25264
as of feb. 09, still holding up great with new owner,
who has since re-geared the rear end and gets nearly 40 MPG!
Old 06-15-2008, 10:37 PM   #82 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Well sorry for the wait ...
Here are the unofficial results of my *******ized Acetone test:
Tank prior to Acetone; 20mpg
Tank w/ Acetone; 23mpg
Tank after, no Acetone; 17mpg
So say what you will the car got better mileage with acetone and had a withdrawal after it was spent ...
I will continue to use it religiously until the engine falls apart. Then I will conclude its bad for the engine .. LOL
1oz per 10 gallon, thats all you need ... Check my log for accurate numbers
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 06-15-2008, 10:42 PM   #83 (permalink)
Blue - '77 Chevy P/U
well i have two cans so i'll be adding for awile
Old 06-16-2008, 12:39 AM   #84 (permalink)
penny pincher
kevlar's Avatar
Weird, I wonder if the number of cylinders and displacement has anything to do with the amount added. I never get a change until I add 2 to 3 ounces per ten....
how it was done...
Old 06-16-2008, 01:27 AM   #85 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I lost quite a few MPG when I tried it. That said, I think it's because tank to tank testing is BS and that acetone doesn't do anything. Even if the test were double-blind tank to tank testing would still be bunk,
Old 06-16-2008, 11:26 AM   #86 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Most homeopathic remedies use great ratios to obtain their effectiveness.
I have a homeopathic "Physician" nearby who swears on the 10,000:1 ratio as best for curing what ails ya.
Just a little humor to lighten the day.
My sister-in-law is a licensed Homeopath.
S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
Old 06-16-2008, 05:16 PM   #87 (permalink)
Ryan - '94 Mazda 323 BASEEEEE
S.
A homo what?
Old 06-16-2008, 05:22 PM   #88 (permalink)
Dartmouth 2010
SVOboy's Avatar
http://en.wikipedia.org/wiki/Homeopathic
Old 06-16-2008, 11:27 PM   #89 (permalink)
Silver EP3 - '02 Honda Civic Si
I tried acetone in my accord a few times, and in my civic once. no real difference I could measure with a scangauge. I get fairly consistent 34 mpg in my 02 Civic Si. The biggest differences were always due to my driving...
http://www.gassavers.org/garage/viewgaslog/1343
MetroMPG.com mailbag: why don't you test acetone? MetroMPG General Efficiency Discussion 21 11-18-2014 06:00 PM
Test: F-150 pickup "cap on" vs. "cap off" @ 60 mph MetroMPG Aerodynamics 17 11-17-2011 02:44 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 09:29 PM
Acetone. Lets get to the bottom of this Nerys EcoModding Central 31 07-27-2009 02:55 PM
Converting Emissions test to C02 g/km? cfg83 General Efficiency Discussion 3 01-15-2008 03:07 PM
