Old 12-06-2009, 08:26 PM   #11 (permalink)
old red taco - '02 toyota tacoma regular cab
90 day: 29.49 mpg (US)
Old 12-06-2009, 08:33 PM   #12 (permalink)
here is some pics of the frame work of my aerocap. this is with a 9" drop from cab to tailgate. which calculates out to a 11.25 degree angle. i am thinking of putting a piece of wood in the center of the span so it makes it a little rounded. any suggestions? should i make change the angle steeper? it seems like most guys making them are making the angles steeper.
i am going to get it all framed out then put 1/2" plywood over the top
Old 12-06-2009, 08:35 PM   #13 (permalink)
Old 12-06-2009, 08:43 PM   #14 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
Why 1/2 plywood? You can make one that is much lighter.
Old 12-07-2009, 05:53 PM   #15 (permalink)
angle vs curve
If you have an abrupt angle,you will lose boundary layer adhesion immediately,flow will separate,and there is a chance you'll have a violent buffeting,enough to "explode" your shell if not robust enough.
Please take a look at Metro's Permanent Kammback for Metro thread,or the Aerodynamic Streamlining Template thread.
You'll notice that the roofline begins with a subtle curvature,increasing with length.
Get a 20-foot length of 1-inch PVC pipe,lay it over the cab and study the curvature as it bends down toward the tailgate.
Old 12-07-2009, 08:28 PM   #16 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
A smoother curve transition is better, but is not an insurmountable problem.
The angle is about right IMHO.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 12-07-2009, 10:48 PM   #17 (permalink)
it is what i have around. i think 3/8ths plywood would be to thin
Old 12-07-2009, 11:54 PM   #18 (permalink)
i am thinking of putting a piece of wood in the middle of the span that is about 1" taller so it bows the upper board up and gives the cap a rounded shape to it.
also should i make the top piece of plywood on the cap extend past the tailgate off the back a bit? i am thinking about extending the plywood as far back as the rear bumper off the back of the truck (about 5") and then on the sides at the back making little pieces that return to the tailgate. making kind of a little kamm spoiler
Old 12-09-2009, 08:03 PM   #19 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
The smaller the trailing wake, the better. If you're willing to extend to the end of the bumper, your wake area will be that much smaller.
I did a similar thing on my car (Kammback out to the bumper):
Old 12-09-2009, 08:28 PM   #20 (permalink)
metrompg i put a protractor over the computer moniter and it seems like your kammback is 15 degrees. would it be better for me to make my cap at 15 degrees to make a smaller flat section behind the truck in turn making a smaller wake?
Report: Improving the Aero Characteristics of a Dodge Ram Pickup Truck MetroMPG Aerodynamics 36 08-05-2013 11:25 PM
2008 Dodge Dakota AeroCap electricman Aerodynamics 52 10-08-2011 10:47 AM
A Pickup Truck Project Big Dave EcoModding Central 47 09-12-2011 11:42 AM
Article: pickup mileage - manufacturers are ecomodding their trucks for better MPG MetroMPG EcoModding Central 14 10-07-2009 11:49 PM
Pickup tailgate up or down skyl4rk Aerodynamics 26 09-02-2008 04:49 PM
