Old 11-30-2014, 10:05 AM   #621 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Some CFD flow images of the car, and some of a standard car without the aero modifications :
The Following 17 Users Say Thank You to Cd For This Useful Post:
3-Wheeler (12-03-2014), aerohead (12-01-2014), BabyDiesel (05-24-2015), BamZipPow (12-03-2014), basjoos (11-30-2014), COcyclist (12-02-2014), Fat Charlie (12-01-2014), Flakbadger (12-03-2014), NeilBlanchard (11-30-2014), PaleMelanesian (12-01-2014), pgfpro (12-02-2014), Piwoslaw (01-22-2015), The donkey CRX (11-30-2014), tyronasauras (12-02-2014), WD40 (11-30-2014), Weather Spotter (12-01-2014), whatmaycome14 (11-26-2015)
Old 12-01-2014, 11:53 AM   #622 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
What got me thinking about the boattail was whenever I drove down a leaf covered road in the fall in the OEM shaped car, I would see leaves continually popping up behind the rear glass in the rear view mirror as I drove down the road. This told me there was a massive recirculating eddy being generated behind the car that was picking leaves off the road and lifting them to the height of the car.
aerocivic.com
The Following User Says Thank You to basjoos For This Useful Post:
Old 12-01-2014, 12:07 PM   #623 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Got a leaf stuck under my rear wiper on Saturday, so I know what you mean!
The CFD is great! It looks like there is some turbulence underneath the rear of the boat tail. Will you be addressing this, or is it not a big concern due to your already ridiculously low fuel consumption?
Old 12-02-2014, 12:07 PM   #624 (permalink)
basjoos's Avatar
I'll just have to live with that turbulence since I occasionally use a driveway with a sharp approach angle and can't have the boattail from dragging the ground when I turn into it.
aerocivic.com
aerohead (12-02-2014)
Old 12-02-2014, 12:20 PM   #625 (permalink)
Sven7's Avatar
Ah, but I figure you've got the ingenuity to design a collapsible bottom! Maybe like those semi truck boat tails.
Cheers
Old 12-02-2014, 04:38 PM   #626 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I've always thought that the car could just have a hinged coroplast skid plate that hangs down with a radiused edge at the rear.
As the car backs out of the driveway, the plate would make contact with the ground and be pushed upward.
When out of the driveway, the plate would lower with the force of gravity and increasing air pressure would provide enough lift to raise it to the perfect angle that the airflow finds optimal.
Two cables would hold it on.
I should add that the CFD images may not be totally accurate, and this entirely due to my lack of understanding of how to use the program.
Sometimes artifacts appeared, and the tests contradicted themselves.
I fully encourage others here that are CFD pros to run professional level testing on the car.
The Following 2 Users Say Thank You to Cd For This Useful Post:
aerohead (12-02-2014), BamZipPow (12-03-2014)
Old 12-02-2014, 04:44 PM   #627 (permalink)
Ahahahaha. Ha ha. Hehehe. He.
How about a hinged, spring-loaded diverter with skegs that have skateboard wheels in the tips?
Old 12-02-2014, 05:00 PM   #628 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Why wouldn't Coroplast work ?
It would be light enough that the airflow would actually lift it to the optimal angle.
Old 12-02-2014, 05:04 PM   #629 (permalink)
how about
Could happen!
Old 12-02-2014, 06:08 PM   #630 (permalink)
I'm sorry, Cd. If you'd said 'coroplast diverter', I could agree.
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 5 06-04-2014 12:14 PM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 12:50 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 02:01 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 10:45 PM
