12-04-2014, 11:31 AM
#641 (permalink)
T-100 Road Warrior
The black Coroplast I have on my dropped front air dam (6 years old) hasn't broken down at all like the "free" Coroplast from the elections. That's even with the free Coroplast being painted and coated. Just something to think about.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 5 Users Say Thank You to BamZipPow For This Useful Post:
12-05-2014, 02:13 PM
#642 (permalink)
I aim for a tail with a top angle of -4 degrees and a bottom angle of 8-10 degrees as a starting point. I have had good success with clear and white coroplast holding up. I also use 1 in. hex mesh wire bonded between .005" sheets of tarp material . I get discarded pieces from plywood shipping covers at a lumber yard or construction site.
12-05-2014, 07:36 PM
#643 (permalink)
Originally Posted by basjoos
Front skirt slightly open with wheels cuts all of the way to the left.
[/CENTER]
would it be possible to make a hinged metal flap to cover this?
When I look at this, I think of metro mpg's test that showed LOWERED mpg because that would have to catch some wind even when closed.
"Ignorance is bliss, but only for the ignorant"-Hypermiler1995
12-05-2014, 07:38 PM
#644 (permalink)
where do you get it?
12-06-2014, 12:52 PM
#645 (permalink)
catch
When the skirt is closed,the gap is within a favorable pressure gradient created by the body camber;with the boundary layer held against the body by the attacking airstream.
There will be a tiny perturbation but it is essentially meaningless.Air pools right there and the outer flow just skips over it.
You can see it in the 'Aerohead's going to the wind tunnel' video,where the air is skipping over the exposed sharp edges of my crappy headlight covers.
12-10-2014, 10:24 PM
#646 (permalink)
halos.com
I got some at Regal Plastics in OKC. There should be sign shops that carry it also.
I've had mixed success with Coroplast. It did well as a fairing, but not good when I used it as an engine belly panel with a couple cutouts. One heavy rainstorm and large puddles...and I ripped it to pieces just rolling through the puddle(s).
The Following 2 Users Say Thank You to ECONORAM For This Useful Post:
12-16-2014, 04:04 PM
#647 (permalink)
Look for plastics suppliers too- the sign companies might upcharge. I did a quick google search and found quite a few in Missouri.
Basjoos, I'm looking forward to seeing what you come up with. It's not easy to improve on perfection, is it?
11-06-2015, 08:46 AM
#648 (permalink)
Lean Burn Cruiser!
I saw that the AeroCivic vanished from the Top 10 highest Gas Car mpg list. Have you been doing the body/drive train modifications that was hinted at?? Hope all is well Basjoos!
11-06-2015, 10:16 AM
#649 (permalink)
It probably dropped off because I haven't entered enough recent tanks. I have several entered in the notebook I keep in the car that I haven't gotten around to entering here yet. I'm doing mostly short distance local driving so its a long time between refills.
I haven't yet done the additional mod yet because funds are tight. Since I don't have the long commute anymore and I 've already done all of the "low hanging fruit" aeromods, this aeromod would take a very long time to pay for itself in fuel savings, especially at current gas prices. My working philosophy is that the aeromods I install need to pay for themselves in fuel savings. But I have the plans for the mod made up and if gas prices shoot up or when finances allow, I will implement it. In lieu of a "real" job, I'm running the family farm now, so the car hobby is taking a back seat except when it results in a cost savings. Both the aerocivic and myself are doing fine.
The Following 6 Users Say Thank You to basjoos For This Useful Post:
11-06-2015, 10:19 AM
#650 (permalink)
Rat Racer
...I 've already done all of the "low hanging fruit" aeromods...
This coming from basjoos!
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following 2 Users Say Thank You to Fat Charlie For This Useful Post:
