Old 05-15-2021, 10:16 PM   #21 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.95 mpg (US)
Originally Posted by AeroMcAeroFace View Post
"Technology has really changed in the last 10 years, so maybe 150 or even 200 mpg is possible now." ah yes the new 200% gasoline, 200% more energy per litre. If anything, worse mpg is expected now due to the higher ethanol content they put in fuel.
Just shows, you don't need to be knowledgeable to be a magazine writer. I will be following this thread ecky.
If in the process of restoration you can add pictures of a how it was done then that would be great.
Absolutely.
I was very much interested to see how Basjoos had done his adjustable front grille block. It's rather ingenious and deserves pictures.
AeroMcAeroFace (05-16-2021)
Old 05-16-2021, 07:30 AM   #22 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Insight aluminum drums
I'm pretty sure the Insight front brakes bolt up too. But they are smaller.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Ecky (05-16-2021)
Old 05-16-2021, 08:12 AM   #23 (permalink)
That would be neat. I'll have to look into it.
The Civic front brakes clear 13" wheels while the Insight ones do not. I'll pull them all what apart and compare. Might just be than the Insight ones are aluminum and thicker.
Old 05-16-2021, 06:16 PM   #24 (permalink)
So I checked and the size difference is 231mm vs 240mm - 3.9%. Brakes are one thing I'm generally very reluctant to downsize, but with such a small difference I'm considering it. The weight difference between the two cars is only around 200lbs, and Aerocivic is more rear biased. And, I'll never be towing with it, something I did (and do) extensively in my Insight.
Aerocivic seems to brake just fine, but I plan to pull the calipers off and service them anyway. Perhaps if the calipers are at all sticky I'll swap them.
Xist (05-16-2021)
Old 05-16-2021, 09:05 PM   #25 (permalink)
Hi! Very cool to see the Aerocivic is still around. What part of Vermont are you in? I've always been curious whether it really lived up to the claimed MPG, so I look forward to hearing your analysis. I'm also curious how hard it will be to get through a VT inspection!
The Following 2 Users Say Thank You to BlueCell For This Useful Post:
Ecky (05-16-2021), MetroMPG (05-21-2021)
Old 05-16-2021, 09:25 PM   #26 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
I don't think Vermont does inspections.
Edit: I see you're in Vermont as well. I didn't think they did. I registered my civic there without an inspection, but it's also 17 years older than the aerocivic.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 05-16-2021, 09:42 PM   #27 (permalink)
I'm just north of Burlington, on the Georgia / Milton border, and work in the Burlington area. I'll definitely bring Aerocivic that way once I get plates on it, but the DMV is only doing things by appointment or mail right now, and appointments are backed up nearly 2 months.
As for inspections, they're actually quite strict here. I expect it'll pass once I replace all of the tired bushings, given there's no rust and no CEL.
Old 05-16-2021, 10:52 PM   #28 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
I've had 13" wheels on my Insight. They just barely cleared the aluminum calipers. I can see some 13" wheels not fitting.
I doubt the slightly reduced braking power or lighter weight of the smaller brakes will noticeable, but it's the cool thing to do (which won't impress anyone either). Of course I have a pair of Insight calipers that will eventually go on the CRXFi.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Ecky (05-17-2021)
Old 05-17-2021, 08:26 PM   #29 (permalink)
Some parts arrived.
The Following 4 Users Say Thank You to Ecky For This Useful Post:
Galvatron1 (05-19-2021), Gasoline Fumes (05-18-2021), PaleMelanesian (05-18-2021), woodstock74 (05-24-2021)
Old 05-17-2021, 09:46 PM   #30 (permalink)
It should be mechanically sound after you install all those parts.
And maybe...
Just maybe...
A coat or two of that “Kilz Hide All” too...
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
The Following 2 Users Say Thank You to redneck For This Useful Post:
Ecky (05-17-2021), Gasoline Fumes (05-18-2021)
