09-05-2015, 11:36 AM
#11 (permalink)
Originally Posted by Cd
The first thing I noticed about Vetters designs are that the insides are very rough and seem to have a lot of sharp edges.
If redone industrially, the rough edges would be eliminated
Craig's latest design and knockoffs are essentially proof of concept vehicles and very much a work in progress.
Some of Rooivalk's designs look a lot like the Ultimate Vetter fairing BTW
Some others, are actually in limited production or have been designed.
09-05-2015, 02:03 PM
#12 (permalink)
I don't have any files saved though, only these photographs. But I can make better renders. When you make a lot in a short space of time it's easier to just photograph the screen. (I am using freeware rendering software that won't allow me to save rendered images)
There are OBJ exporters for the free version of Sketchup.
And while the program might not save images, there is always Shft-Cmd-3 (screen) or Shft-Cmd-4 (selection) to save. If you find yourself in Windows it's Alt-PrintScreen (a dedicated keyboard key). Then you have to save in Paint or something.
09-05-2015, 04:14 PM
#13 (permalink)
The use of materials such as honeycomb aluminum can give very good crush characteristics when designing for impact protection. Rigid foam sections as in helmets help too. Consider a lap belt in a full body fairing. Knee and face injuries are most likely.
The Following User Says Thank You to Grant-53 For This Useful Post:
09-05-2015, 04:16 PM
#14 (permalink)
With some careful thought a good all weather scooter shell is possible. The fuel mileage could be double that of stock and excellent crash protection provided. A bright two tone paint scheme and marker lights would make it highly visible. Articles from the SAE journal and race car construction can be very helpful.
09-05-2015, 08:31 PM
#15 (permalink)
If you wouldn't want a tricycle to lean in a turn, something a little wider like the Piaggio Ape and its Indian copies would be a good base. Then you could even attempt to make a "family-oriented" version of your project.
09-06-2015, 02:50 AM
#16 (permalink)
Gyroscopes.
09-06-2015, 07:03 AM
#17 (permalink)
Something like a Dymaxion car? https://en.wikipedia.org/wiki/Dymaxion_car
09-06-2015, 12:48 PM
#18 (permalink)
The Dymaxion would be a better example to follow than say the Campagna Motors T-Rex because it has a lot more internal volume; important when you scale it down to your size. It's being discussed right now in another thread:
The question to be answered by my following aerohead's dimensions would be the difference between a pointed tail like The Template and a rounded tail like the Dymaxion.
I've been struggling with an English translation of Kamm's research and what I can say is, 'don't do 'rounded' truncations.Make the cut as if you'd do it with a bread knife.Straight chop.
There's your opportunity for taillights and license plate. They both have a wide track to compensate for zero track in the rear.
Here's my own design for a(n un-truncated) Dymaxion clone:
It's advantage would be the mathematically defined shape lends itself to formless construction. Since it is malleable it could provide a narrow body for a two-wheeler as well.
09-06-2015, 02:17 PM
#19 (permalink)
Thanks, most of the designs you'll see in the links I left in my second comment in this thread are straight chops for this reason, It would allow for taillights and a numberplate, without drastically affecting airflow like a curve would. I'd have to say my favourite design of mine so far is this one, because it has good visibility and crosswinds shouldn't be a huge problem, as well as the numberplate thing: The rest of the fairings 4 September - Album on Imgur
09-06-2015, 05:45 PM
#20 (permalink)
I see that was the one you chose for your avatar.
I don't know how much you've poked around this site. Have you seen Allert Jacobs 125cc Honda? It has an interesting solution to ingress/egress.
Also concerning Craig Vetter's rough interior; http://ecomodder.com/forum/showthrea...ion-32556.html Hit on the left, injuries on his right.
