Old 04-17-2012, 07:44 AM   #331 (permalink)
Originally Posted by ERTW View Post
lifting bodies are new to me. There's a pdf in post #2.
Lifting Body Design - The Rocketry Forum
the flat is on top, and it flies at a large angle of attack. I'll explore any tech transfer to ground vehicles (specifically my malibu
Thanks, the PDF in post #2 goes a long way in explaining how it's supposed to work.
There were another series of lifting bodies from the early 1970's which had flat bottoms and flew in level flight. Which is why these inverted cone ones always look upside down to me.
Lifting Bodies » Galaxy Wire
Collect Aire 1/48 X-24B Lifting Body
Here is the X-24 with the original short nose.
NASA - NASA Dryden Fact Sheet - Lifting Bodies
I built a metal model similar to these in shop class around 1974, I was 14 years old and was crazy about aircraft. It weighed a lot, covered the spars with heavy aluminum foil, it never flew but was always meant to be a static model anyway.
EDIT:
http://s184.photobucket.com/albums/x...%20and%20Ends/
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 04-17-2012, 09:51 AM   #332 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
(C)
Originally Posted by cfg83 View Post
aerohead -
Here is a normal 1980's Trans-Am with a spoiler that appears to closely match your template :
Now, if we were to turn the Trans-Am into a "Limo Trans-Am", I would like to know how to apply the template. Assuming I elongate the Trans-Am from the point of max camber, would I (B) keep it in the same place? :
Or (C) be allowed to slide it to meet the spoiler? :
CarloSW2
(C) ... but dictate by roof not spoiler. If the doors are stretched then aft body template fit should be the same as (A). With a flat roof the max point should be that furthest back generally speaking.
Recreation Engineer
The Following User Says Thank You to KamperBob For This Useful Post:
aerohead (04-17-2012)
Old 04-18-2012, 12:44 PM   #333 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
KamperBob -
Ok, thanks. Let's use a better example, the Toyota Matrix :
Now, if we were to turn the Matrix into a "Limo Matrix", I would like to know how to apply the template. Assuming I elongate the Matrix from the point of max camber, would I (B) keep it in the same place? :
CarloSW2
American Solar Energy Society
Old 04-18-2012, 12:48 PM   #334 (permalink)
Come on now, you know the answers!
It's "B" if you are after that extra count of lower drag and are willing to chop the roof up; and "C" if you want practically the same aero result without all the work and reduced interior volume.
Like I said, nothing sticky-outey (looks like "C" could be back a skosh further too, or pull that spoiler off).
Old 04-18-2012, 01:00 PM   #335 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
aerohead -
Would these two elevations be equally aerodynamic? :
CarloSW2
Old 04-18-2012, 01:08 PM   #336 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Frank -
I want aerohead to chime in. Years ago he told me that I couldn't slide the template back on my wagon to "fit the template".
I knew someone would point that out. I think that the spoiler is deliberately sticking out to "trip the flow" (not the right term?).
CarloSW2
Old 04-18-2012, 01:25 PM   #337 (permalink)
I know; I was waiting for him too but he endorsed #332 so I figured "he has spoken". Don't know why he would have said not to slide it back.
I'll chime in on the Limo Template: It would gain just a wee bit of drag due to the increased skin friction from the increased surface area.
P.S. And in YAW the limo will have a bit more "frontal" area.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
cfg83 (04-18-2012), COcyclist (04-15-2020)
Old 04-18-2012, 04:53 PM   #338 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
aerohead -
CarloSW2
I can answer that for you. The forward and rear shapes are the same, but the wetted area is greater. It will have a little more drag based on that observation.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
cfg83 (04-18-2012)
Old 04-18-2012, 05:50 PM   #339 (permalink)
equally?
aerohead -
CarloSW2
Frank Lee and Skyking covered the answer as I would have.
You're basically just adding a constant-velocity section in between the acceleration and deceleration sections.
You'll see this done on commercial jetliner fuselage and submarine hulls.McDonnel Douglas has kept stretching the original DC-9 to end up with today's MD-80.
The antithesis would be the Granville Brother's Gee Bee R-1 racer which is one of the shortest but aerodynamically correct forms when viewed in plan.Jimmy Doolittle had to fly this plane bare-footed,as it was very sensitive to control surface corrections and tended to 'swap ends.'
Mair stuck a section like this into his boat-tailed wind tunnel research model.It is nearly identical to a Gavre artillery projectile which you'd see fired from a howitzer at the Aberdeen Proving Grounds and it has an identical drag coefficient of Cd 0.20,before the boat-tailing begins.
PS I should mention,that by extending the body,the SAE break-over angles would no longer be good and unless you had active suspension to raise the car around town,you'd likely suffer a ground strike at the summit of some driveway ramps.Hate it when that happens!
cfg83 (04-18-2012)
Old 04-18-2012, 09:23 PM   #340 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Frank and skyking and aerohead -
Thanks for the corrections. I am happy that I can slide the template for my wagon :
CarloSW2
Maximum angle for boat tail? abcdpeterson Aerodynamics 80 11-03-2021 12:55 PM
Aerodynamic Streamlining Template Part-B aerohead Aerodynamics 8 05-31-2013 12:23 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
Aerodynamic Streamlining Template: Part-A aerohead Aerodynamics 0 07-18-2009 02:37 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 04:14 PM
