02-21-2015, 10:52 AM
#71 (permalink)
T-100 Road Warrior
Put a supporting strip of wood behind the Coroplast so it can't slide down and in. I can't tell which part of the trailer this is from yer piccie. Is this the front of the nose where you have a wood strip on the front?
Dark Aero-The world's first aerodynamic single wheel boat tail!
02-21-2015, 10:55 AM
#72 (permalink)
Yes, that's correct. That's a picture of the nose from the front. You're seeing the driver's side.
02-21-2015, 11:09 AM
#73 (permalink)
T-100 Road Warrior
Any thought on an inflatable nose?
02-21-2015, 11:17 AM
#74 (permalink)
My immediate reaction is, "how the would I construct it?"
100% filling the void space between trailer and car would be excellent, but I'm uncertain how to even approach that.
02-21-2015, 01:06 PM
#75 (permalink)
how
My initial proof of concept for an inflatable structure involved a shallow wooden box with a section of bean-bag chair envelope stapled to its perimeter.
A Bosch 12-VDC ventilation fan from a VW Westfalia Campmobile was used for inflation and tensioning.
A long pigtail ran under the vehicle to the engine compartment and alligator clips on the two leads attached to a ground strap and positive post of the battery.
With power on,the bag inflated in a few seconds,and it was stiff enough to resist deformation during driving.
Later,I fabricated a full-scale mockup of a properly shaped envelope and used it as a pattern to cut and sew the second envelope.
This second,longer (4-feet) envelope,'wagged' up and down,so I ran a cantilevered suppport under its length.No more wag.
02-21-2015, 01:53 PM
#76 (permalink)
T-100 Road Warrior
Maybe you could git a cheap twin Aerobed on Craigslist and use that? You'll need an AC inverter to run the pump so you can inflate it. You'll need to provide some wear protectors so the rubbing won't kill the mattress.
Here's some in Houston fer $25 each...
air mattress (3)
The Following User Says Thank You to BamZipPow For This Useful Post:
02-21-2015, 01:59 PM
#77 (permalink)
T-100 Road Warrior
02-21-2015, 04:08 PM
#78 (permalink)
Hah!
Incredible looking trailer. I'd love to build something like that one day.
There're a number of them. Here's two from my 'Pieces and parts' album:
Actually, I'm thinking of taking ~4 sheets of coroplast per wheel with a bit of metal framing, bending them, and making a rough teardrop that just sits over the stock fenders.
I have had an idea for some time that needs to be documented (maybe the next time I'm frustrating myself with the 3D modelling programs). Three or 4 lens-shaped pieces, the top one fixed, the others hinged at the front and back. They would be shingled and retract up under the top pieces for access for tire changes, etc.
Fight air pressure with air pressure. My thought is inner tubes trussed up with polyproplene rope. a big one in the middle, a pair of smaller ones to each side, and scooter tire inner tubes bracing those.
04-16-2015, 06:20 PM
#79 (permalink)
Update!
I'm trying not to buy anything since my move-date is so near, but I found a use for some scraps that otherwise would have gone to the recycler.
The wheel-skirts are made of some bits of scrap aluminum sheeting I had, patched together and reinforced with some aluminum flat to hold it away from the tires.
Replacing the tire might be more annoying now, but it's really not much more than a few screws.
The Following 3 Users Say Thank You to Ecky For This Useful Post:
04-16-2015, 06:26 PM
#80 (permalink)
telling the air "just move along, nothing to see here"
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 2 Users Say Thank You to skyking For This Useful Post:
