Old 05-21-2017, 05:02 PM   #31 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Originally Posted by Old Tele man View Post
Did it have the V4 engine? My Dad had one too, with the Ford V4 industrial street sweeper enigine.
I had a Saab 95 (the station wagon version of the 96) with that engine. Absolutely bomb proof motor. Wish I could say the same about the transmission.
Old 05-21-2017, 08:17 PM   #32 (permalink)
The problem with these old cars is that all the glass is inset deeply into the body.
Solvable problem. Picture a lead sled Merc time attack car. Smoked gray plexiglass from the drip rail to the beltline crease, wall to wall on the door and from the B-pillar to the end of the drip rail over the quarter-window.
Then a driver's window like this:
Live From Socal, The Evasive Fr-s #featured - Speedhunters
mercguy1951 (05-28-2017)
Old 05-27-2017, 12:03 PM   #33 (permalink)
tunnel
Originally Posted by mercguy1951 View Post
I use a small diameter rubber hose as my stethoscope. I'm out of town right now, but when I get back to the Merc I want to try to add some small blocks and tape on the A pillar to see if I can smooth the air flow around it. Also I may try to tape the back of the front door glass to prevent air leaking into the door and see if that helps. I'll try removing the mirror too.
The problem with these old cars is that all the glass is inset deeply into the body. The windshield has bulging rubber and stainless trim around it too. I wish we had access to a wind tunnel we could use to work on these problems
You'd be looking at either the A2 tunnel in Mooreville,NC (@ $480/hr for the 1st 2-hrs),or DARKO,Ogden,Utah ($500/hr).
Old 05-28-2017, 05:11 PM   #34 (permalink)
Wow, that's expensive, but I'm glad to know that the service is available. Thanks!
Old 05-28-2017, 05:21 PM   #35 (permalink)
Otoh:
"if it looks right, it is right."
dorothy draper
Old 05-31-2017, 07:56 PM   #36 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
I thought of a diagnostic tool for you.
stick on window sealer for your house it's meant to be put on the inside of your windows to reduce drafts. Try to find some that is a push to stick type then you heat it with a hair dryer and it shrinks. Do just the inside window to test the felts... if not tbere then start covering suspect places. No idea how well it sticks
Just an idea.
Dreem Big Chisel Down To Reality
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 06-01-2017, 11:08 AM   #37 (permalink)
Just an idea.
Thanks! I'll look for that at my nearby Home Depot
Old 07-14-2017, 04:18 PM   #38 (permalink)
teoman's Avatar
A3 - '12 Audi A3
If all else fails get some noise cancelling headphones
Old 07-14-2017, 04:20 PM   #39 (permalink)
teoman's Avatar
A3 - '12 Audi A3
You claim the noise also exists on the passanger aide.
Get some one else to drive while you hunt around on the passenger side.
Old 07-14-2017, 05:24 PM   #40 (permalink)
Aerodynamic wind noise suppression
Thanks, I have been using my noise-cancelling headphones on those long high-speed trips for some time now
There is NO doubt that the same wind noise is on both sides. It is loudest at the "A" pillar and at the lower part of the door glass just above the door handle
Guess I'm getting old, loud sounds really bother me
