Old 03-02-2017, 10:54 AM   #21 (permalink)
Less waste = better FE
Hi Stubby79
Sorry for the confusion with the names, I am a 78 model myself.
I agree with you. Adding supercapacitors can be done to make the regenerative breaking better, but what do you do with all the extra power. The battery will soon be fully charged. So you need some motor to get the power back to the wheels.
I have already changed most of my lights to LED's, so the battery doesn't need much charging anyway. It is just the charging power that got wasted as gassing that I wanted to stop with this circuit. At the same time it also lowers the alternator power requirement during normal driving.
Old 03-02-2017, 12:18 PM   #22 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Extra energh! WOHOOO!
Generate HHO!
Just kidding.
One would need to size the battery according to your driving situation. If you brake a lot, then a smaller battery may suffice as it will get charged a lot. If a lot of highway miles then the batteries would need to be bigger to be able to go longer without using the laternator.
The super capacitors (there are a couple of threads on this forum) are a bank of 6 rated to 15V when combined. They are ~3000F each and they can hold about 3 seconds of cranking power at most.
I think that the capacitor idea was referred to in conjunction with a deep cycle battery. At the end of a brake'less trip, if the battery is too low, it will not start the car. But if you have capacitor bank that may be able to push enough amps to start your car. Or it is very quick and easy to boost up the capacitor so that it is capable of starting your car again.
Old 03-02-2017, 03:45 PM   #23 (permalink)
I'd rather have a starter rope. I trust them.
Old 03-02-2017, 04:03 PM   #24 (permalink)
Nobody is stopping you from doing that Frank. I'd like to see the DIY thread on it.
Old 03-02-2017, 04:04 PM   #25 (permalink)
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
I would love to see that on your F150
Video please
Old 03-02-2017, 04:07 PM   #26 (permalink)
As of now I have functioning electric starters and conventional batteries. But I've thought about starter ropes for my vehicles- at least the 3 and 4 cyl ones- for years. It would be nice to ditch the battery and the starter, wouldn't it? Would just need a magneto on the non-EFI ones for ignition; for the others a wee battery and charging system for the electronics or maybe a bigger deep cycle battery and plug-in regimen.
http://www.thesamba.com/vw/forum/vie....php?p=3148116
https://www.google.com/search?q=rope...hrome&ie=UTF-8
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
freebeard (03-02-2017), gumby79 (03-02-2017)
Old 03-02-2017, 04:46 PM   #27 (permalink)
Lurking Eco-wall-o-texter
So you want a no-battery starter...
Hello Frank Lee,
I think you might find this interesting: Home - Kineteco
Also these guys: Startwell Engineering – Mechanical Starting devices for Diesel Engines from 0.5 to 18 litres
They have applications for many common engines, mostly industrial/agricultural.
Crank up the spring, hit the release, starts engine.
Several years ago I was looking for one to fit a 292 GM or 300 Ford I-6, and I did find it as a viable application, but it looks like it isn't a standard offering anymore.
BTW, great circuit DieselJan. If I understand it right, this circuit does enable "regular" charging if the battery gets below a voltage you set with the correct diodes, as well as the "charge when brake circuit is active"? IE, it's "foolproof" barring a sudden overnight drop in temperature on a barely-above-set-charge-threshold battery.
Does it continue to charge when you sit at idle at a stoplight with your foot on the brake?
Thanks,
-cajunfj40
The Following User Says Thank You to cajunfj40 For This Useful Post:
Frank Lee (03-02-2017)
Old 03-02-2017, 05:16 PM   #28 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
AutoSpeed - Digital programmable voltage switch
Some thing like this .
Use function #F5 Relay off when voltage between P1 and P2. On at other voltages.. p= parameter/voltage
Use the TPS 0-5v signal to activate the charge mode at any point outside of cruse.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
DieselJan (03-03-2017)
Old 03-02-2017, 06:45 PM   #29 (permalink)
Frank Lee -- My green Superbeetle would start within 1/4th revolution. Don't ask me why.
And I carry a 48" leather strap at all times.
Old 03-03-2017, 01:07 AM   #30 (permalink)
You're all set!
alternator control, alternator delete, reduce alternator load, regenerative braking
