Old 12-13-2017, 03:30 PM   #51 (permalink)
https://duckduckgo.com/?t=palemoon&q...ages&ia=images
Two wrongs don't make a right, but three lefts do.
Old 12-13-2017, 07:14 PM   #52 (permalink)
I get the truck back from the bodyshop tomorrow at 10. then on Saturday I'll have 90ish miles to run the tonneau cover. Im not sure its worth filling up before/after both ways for such a short term trip.
I'll be installed an billet aluminum wheel with drastic changes in the fins for a faster spool time, a high flow outlet, and about 5psi boost. I don't think it will help fuel economy but I bought it before the ecomodder hobby became more realistic.
According to Big Dave the exhaust back pressure delete will help in the winter at least. Its a little butterfly valve that restricts air flow to promote warm ups but its constantly prone to failing (not opening/closing all the way) and causing an oil leak. so it may be small but: less throttle, faster spool times, reduced egts, free-er flow should help even if its ever so small lol. I'll post pics.
Old 12-17-2017, 08:16 PM   #53 (permalink)
Got truck back on Thursday and double checked all fluids and installed the tonneau cover. Won’t be very accurate for measurements this tank but any improvement above 15 will be nice. Been having a lot of town lately but in about a week almost 2k miles 90% freeway of testing
The Following User Says Thank You to gone9 For This Useful Post:
aerohead (12-20-2017)
Old 12-17-2017, 11:12 PM   #54 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
a test loop is of~100 mi each way same 2 pumps at each end is whst I do for testing . I have found a distinct 2mpg non verable difference North Vs south.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
Old 12-17-2017, 11:13 PM   #55 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
a test loop is of~100 mi each way same 2 pumps at each end is whst I do for testing . I have found a distinct 2mpg non verable difference North Vs south. +
Former
87' Hyundai Excel
Old 12-18-2017, 12:03 PM   #56 (permalink)
Unfortunately my total commute to work is under 30 miles and about 50% city. Once a week I drive about 102 miles (Im taking night classes in sacramento). but the holiday brakes removes the 102 miles trip until Jan 4th lol.
I leave this weekend though around 0-dark-30 and looking forward to hit. Plus drove the truck this morning without the exhaustbackpressure valve and wow! brought back all the performance....
I attached a picture of the little outlet on the exhaust side of the turbo charger. The little valve is a source of oil leaks with a $200 rebuild kit and really reduces economy of the 7.3l powerstrokes until warmed up. (not worth the warm up time, I never noticed it reduce the time at all).
Old 12-19-2017, 06:54 PM   #57 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Yup. You found it.
My EBPV would clog up and run in "warm-up" mode from September to April.
Like running with an exhaust brake. Its why so many diesel pickups get lower MPG in the winter (over and above the denser cold air).
In fact some guys have rigged them up for manual control and used them as cheap and dirty exhaust brakes. Very handy retarding that trailer down a hill and much cheaper (if less reliable) than commercial exhaust brakes.
Downside: It take 4-5 miles for the truck to warm up enough for the heater to pickup.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following 2 Users Say Thank You to Big Dave For This Useful Post:
aerohead (12-20-2017), slowmover (12-24-2017)
Old 12-20-2017, 12:57 AM   #58 (permalink)
Removing the EBPV made cold driving so much better... my chip has a no start and high idle mode in addition to various tunes for towing, driving etc.
The high idle and no ebpv made it much more enjoyable lol.
Have a confirmed source on air dam material too. Soon as I’m back from Idaho I’ll get it. He can cut and drill it for me too. So getting excited. Only day two or tonneau cover too.
The Following 2 Users Say Thank You to gone9 For This Useful Post:
Old 12-24-2017, 03:19 PM   #59 (permalink)
Well I didn’t plan on the winter blend of diesel being so bad.
First fuel up in Klamath Falls Oregon was 17 mpg, second I’ll up in Biggs Oregon was 17.291, third in Spokane WA was 16.7 and I never went over 70 mph. And even had a good 100+ mike section of under 50mph because of ice/snow on the roads. It was around 30-20 in Oregon and it’s 12 degrees right now in Sandpoint Idaho.
I know they cut diesel differently in the winter but dang. I was hoping for a solid 18 at least lol. Tonneau cover did very well and this was only after driving for about 12 hrs.
Old 12-24-2017, 05:40 PM   #60 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
Wintry mix will penalize mpg. Wet roads cause increases in tire slip, reducing mpg. Had the wether been cooperative you may have hit your 18mpg goal.
How did hwy97 compare to I-5?
Big Dave , would that flap valve bolt to a Hx35/40 turbo?
Former
87' Hyundai Excel
