Old 10-10-2013, 11:55 PM   #11 (permalink)
MPGsteward's Avatar
Project Ranger - '07 Ford Ranger XLT
90 day: 33.69 mpg (US)
Lead Sled - '94 Mazda B2200
Still havent burned through a tank of gas yet, but the ranger is getting over 30 mpg. Part of the tank was drove without any aeromds done, so its looking good so far. Got pizza pans this week for it and mounting hardware. will post how i attach the pans and progress on mpgs.
Old 10-11-2013, 09:56 AM   #12 (permalink)
so you removed your front bumper? also when you were planning your dam, did you consider making the dam wider so it could clear the front tires (on lock) and extend over the front wheel wells?
Old 10-11-2013, 01:00 PM   #13 (permalink)
MPGsteward's Avatar
Yes the front bumper is removed, the air dams I have built fit better without the bumper & makes the truck lighter. The abs sheet is 8' long and I have not seen one any longer than that, but you could use two pieces & have them buttress in the middle. I did not consider extending over the front wheels. Nice idea, but it would take a lot more time then what I have invested in the one I built.
Old 10-18-2013, 11:53 AM   #14 (permalink)
MPGsteward's Avatar
32.84 MPG on my 1st tank. My MPG is actually higher though. I drove the 1st 1/4 or more of this tank without any mods. Im pretty stoked & cant wait to get the next big mods completed i.e. pizza pans, aero topper, & side skirts.
Old 10-22-2013, 06:23 AM   #15 (permalink)
In the late 90's I had a 96 Ranger, 2.3L, 5 speed
When the doughnut went out between the muffler and cat, I said screw it and bought
the Dynomax,(then $100) exhaust
I was shocked when it picked up 2-3 MPG's after the install.
The Following User Says Thank You to Keito For This Useful Post:
MPGsteward (10-22-2013)
Old 10-27-2013, 04:42 PM   #16 (permalink)
MPGsteward's Avatar
Aluminum pizza pans added this weekend. Cut 1.5 inch holes to access valve stem. Covered with a metal hole plug. a step bit or auger bit works well to cut the hole perfectly.
Old 10-27-2013, 06:58 PM   #17 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
looking good!
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
The Following User Says Thank You to HydroJim For This Useful Post:
MPGsteward (10-27-2013)
Old 10-27-2013, 07:54 PM   #18 (permalink)
nathan01xl's Avatar
The Long Ranger - '01 Ford Ranger XL
Pickups
90 day: 28.68 mpg (US)
EcoSI - '08 Honda Civic SI
90 day: 28.83 mpg (US)
Needs more low, drop coils and flip rear spring hanger for a cheap 2/2 drop.
How did you attach your pizza pans, i have some lying around i haven't installed yet because i cant decide the best way to do so.
Old 10-27-2013, 10:10 PM   #19 (permalink)
MPGsteward's Avatar
Lowering not an option for me since i need to haul 1 ton of material. Pans attached with toggle bolts. It works, i used them on both my trucks.
Old 10-28-2013, 12:28 AM   #20 (permalink)
nathan01xl's Avatar
Pickups
If you need to haul 1 ton of material you have the wrong truck, your max payload is 1200 lbs and you will be riding axle on frame, i just about was with around 800lbs in the bed.
