03-05-2011, 05:34 PM
#101 (permalink)
T-100 Road Warrior
Pulled the aero cap apart and have started tapering the rear a little bit. Since I made the aero cap modular, I just had to take out some screws and pivot the sides in. Some support straps to fix it in place, measure some new panels and screw them in. Redo the hatch fer the new setup. I'm looking at pulling the sides in about 6"...12" overall.
A rough estimate on the left side...
The cap opening will be about 48" wide at the rear.
03-05-2011, 08:46 PM
#102 (permalink)
T-100 Road Warrior
03-05-2011, 09:05 PM
#103 (permalink)
Wow, too bad mine is disassembled and under about 3 feet of snow right now, or I'd put up some pics of it... looks very similar to what I built, coroplast over wood and everything. Mine has no "twist" on the sides though, and in side view the top has an arch, not straight...
03-05-2011, 09:34 PM
#104 (permalink)
T-100 Road Warrior
My hatch will still have the arc...I just haven't gotten to finalizing my sides yet. I'll post up piccies when I git to that stage though...
03-07-2011, 09:56 PM
#105 (permalink)
T-100 Road Warrior
Progress fer today...
Had to take the hatch apart since the aero cap dimensions had changed. Since putting the original together...I learned a lot and applied it to this version. It's a little more accurate as far as measurements go...
Hatch frame resized...
Decided to lose the 2 extra sheets of 4x8 Coroplast from the original setup and made some 5" strips to take their place...
Main cover back on...only a single 4x8 sheet!
Used hot glue as a basic sealer fer the sides...the duct tape is just a temporary gap filler.
I still have to put in the rear window and hook up the interior lighting. I might end up trimming the back end a little...not exactly sure yet.
The Following 3 Users Say Thank You to BamZipPow For This Useful Post:
03-22-2011, 11:02 PM
#106 (permalink)
T-100 Road Warrior
The aero cap held up pretty well...until I encountered some heavy winds just South of Dallas. The hatch main supports were bowing up pretty badly...so I had to pull off the road and tape the entire hatch down just in case the main hatch exploded. Made it home without any incidents!
Now before I take this version apart and start working on my next version...I'm putting the 2 extra sheets of Coroplast back on top of the hatch to see if it will stabilize the bowing and flexing I was seeing as I was driving.
You can see the bowing here...this was at 65mph and about a 30mph crosswind...
05-19-2011, 09:19 AM
#107 (permalink)
I've Been AeroHauled
Hello,
Just joined this forum and have been doing a lot of research and kept finding things I'd do different until I saw your shell. You must be an engineer. You've got the slope right and the over hang and the side skirts. Have some closer pics? Have you posted details on your mods. Can't find any??
I've got a Tacoma. Could use your help. Where did you find your air dam and how did you make your side skirts? It looks very well done.
I've started on an aero shell, but am wrestling with materials right now.
Thanks!
David – minAirForce
05-21-2011, 08:51 PM
#109 (permalink)
T-100 Road Warrior
Added in some support to the hatch...the airflow over the top during some instances would severely push down on the skin and looked like it would collapse.
It's basically some ¾" Sch 40 PVC pipe that I cut and just wedged in there. A few screws to hold it in place. It's basically fer testing.
05-22-2011, 09:46 AM
#110 (permalink)
Recreation Engineer
Keep up the good work. Love the incremental updates.
The buckling under way intrigues me. I wonder if it's positive pressure above or negative pressure below. Have you been able to tuft test that area with a chase car for example?
Rock on!
