Old 08-14-2011, 07:29 PM   #161 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
"J" channels are installed...
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (08-16-2011)
Old 08-14-2011, 07:42 PM   #162 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Had to make a new cab cover since I've decided to close up the gap between the cab and the aero cap. This will allow me to install my ducktail, too. I'll have to figure the best way to store the cover. I really liked my first cab cover...
From the top...
Front side view...
My high tech fastening system...
Old 08-15-2011, 10:25 AM   #163 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Still interesting as always, BZP. Keep up the great work. You're practically doing a thesis project here.
I'm curious about your cab cover. What's your favorite purpose? Less solar gain? Keep tree sap off the windows? Inquiring minds want to know.
Recreation Engineer
The Following User Says Thank You to KamperBob For This Useful Post:
BamZipPow (08-15-2011)
Old 08-15-2011, 11:52 AM   #164 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
It's basically a radiant heat shield. It also keeps the bird/tree crap off the top/glass, too. Can't argue with that. Haven't tested it in the winter but I'm sure it would keep the ice/snow off just as well.
My first attempt was very basic...this is my truck cab cover thread. It's basically secured to the open truck bed so it makes it very easy to deploy/store. It only took me about 10 seconds to deploy it and about 30 seconds to store it away. I tried it with the aero cap on but on windy days it would git caught up on the passenger side part of the aero cap. It's very marketable to the specific pickup truck market. I'm still playing around with designs/materials. The other products out there don't come close to my design...and their covers last about 1-3 years depending on the material. I would expect more like 1-2 years.
I was busy this morning... Pulled the side panels and cut the brackets that were sticking out a bit. Patched the sides (temporary) so I can git on the road...
I still have to figure out a way to put the ducktail on. Why a ducktail you might ask? This is why...gotta keep that rain off the back window and the air/debris out of the bed.
Old 08-15-2011, 06:17 PM   #165 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Time to cheat...
Brackets are marine epoxied to the cab...and the Gorilla tape is just holding it in place so it doesn't slip and set wrong.
We'll see if the ducktail stays in place this time. If the marine epoxy works on Coroplast...I know what I'm gonna seal the front edge with.
Old 08-15-2011, 09:50 PM   #166 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Got the ducktail in place now...
Used some aluminum tape to tape the leading edges of the ducktail and aero cap. We'll see how well the aluminum tape holds up...
With the brackets secured to the cab and the ducktail secured through the brackets into 1"x2" wood strips...I don't think this ducktail is going anywhere or flipping up from the rear like my previous versions did.
After this trip, I will trim the leading edge of the sides so they don't extend onto the cab.
Old 08-15-2011, 10:04 PM   #167 (permalink)
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Nissan Frontier XE
90 day: 27.87 mpg (US)
looking smoother every day! It is really starting to take shape. Looks like the profile is comming out very nicely.
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
The Following User Says Thank You to graydonengineering For This Useful Post:
BamZipPow (08-16-2011)
Old 08-16-2011, 04:52 AM   #168 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
You do realize you're slowly gravitating towards aerohead's T100
The Following User Says Thank You to euromodder For This Useful Post:
Old 08-16-2011, 07:19 AM   #169 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Well...he has a long bed while I have a short bed. He has a manual transmission while I have an automatic transmission. He has a 4 cylinder engine while I have a 6 cylinder engine. His aero cap doesn't have a hatch while mine does. His aero cap won't disassemble while mine can.
I am still inspired by his work and will continue to dedicate my build towards the same goal...
KamperBob (08-16-2011)
Old 08-16-2011, 09:19 AM   #170 (permalink)
Recreation Engineer
KamperBob's Avatar
Thanks, BZP. Tyvek: cool.
PS: Phil's T100 is 4-cyl? Interesting...
Recreation Engineer
found another aero cap AeroAl Aerodynamics 5 05-19-2011 12:00 PM
Truck Aero, Bed cover DIY tonneau? Chris D. Aerodynamics 84 11-04-2010 11:56 PM
CLASS - 8 Truck Streamlining Benchmark aerohead Aerodynamics 0 02-28-2009 03:17 PM
CLASS-8 Truck Streamlining / Fuel Economy ( Part-1 ) Aero Specifics aerohead Aerodynamics 1 02-23-2009 05:16 PM
Yet Another Pickup Truck Aero Idea Big Dave Aerodynamics 14 05-03-2008 03:17 PM
