Old 04-22-2011, 11:59 PM   #11 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
The 195 is the stock thermostat, use it. I've tried 180 and 195, 195 was superior. Don't worry about how often the fan runs, you can manage that with good ducting.
Old 04-23-2011, 01:17 AM   #12 (permalink)
ZX2ner
The Z - '99 Ford ZX2
90 day: 35.3 mpg (US)
Wow. These things like to run pretty hot then. I'll have to change that out this spring since it's simple.
Sorry, new users are not permitted to post links in their signatures.
Old 07-02-2011, 05:25 PM   #13 (permalink)
Originally Posted by Tygen1 View Post
Good to see you here LmidgetD I presume you are on TeamZX2? If not, then get there.
When you mod your car, you need to mod it around your drive/commute. I spend a lot of time at 50mph and holding it steady, so aero mods and lean burn really help. Aeromods won't help you if you are in the city or in traffic. So lets talk about your drive before you go too crazy.
I like to compare Basjoos vs. PaleMalnsian {sp} Basjoos has modded his car the highest degree and get's excellent results. PaleM. has almost no mods and just uses PAG to get excellent results as well. You should read up a bit on those guys and look at what they have done to get an idea of what you can do.
I have an ATX, so my commute is well suited to it. You have an MTX, so you have a bunch of options that are open to you adjusting the way you drive. On TeamZX2 you will see a little post I had about a 107mpg ZX2, read about that guy to get some ideas. I also got a worklog over their that covers almost all of my mods in some detail.
Ecomodding is a natural step from "tuning".
It is possible to have performance and mpg as well. 98% of the time, I am driving slow and boring, but occasionaly I like to take it to the drag strip
Hi Tygen1-- I've wondered what would be needed to get my ZX2's engine running lean. Could you offer any recommendations? Thanks!
Old 07-04-2011, 09:42 PM   #14 (permalink)
Team ZX2
I wouldn't sugget doing this unless you are extremely confident in your skills. I've been modding cars for quite some time and I can change out the motor or transmission if I cause any problems.
If you have the skill and resources. Then you would start by getting a tuning program such as SCT PRP, Sniper or Tweecer to learn the tuning ropes, then once you have a quality Wideband O2 sensor to monitor how lean you are, you start to tweek the AFR to run lean under a light throttle cruise.
The Zetec motor seems to respond well to running lean
Old 07-05-2011, 10:25 AM   #15 (permalink)
Wannabe Ecomodder
Oldmanmobile - '90 Buick Lesabre Limited
90 day: 29.51 mpg (US)
I'm assuming that the OP was intending to run lean by disconnecting a vacuum line. I've found that while it does improve your fuel mileage, it also does terrible to things to your engine if you don't regulate it.
I accidentally blew off a line on my Supercharged Mustang GT and while I got 26 hwy mpg, I popped the headgasket in about 1000 miles.
Lesson learned.
Chris
1993 Jeep Wrangler 21.7 mpg
1999 Volvo V70XC 21 mpg
2003 Toyota Prius 44.1 mpg
Old 07-05-2011, 01:34 PM   #16 (permalink)
Team ZX2
The disconected Vacuum Line does not cause the engine to run lean. It just fools the PCM into thinking less air it going into the motor than actually is, therefore it believes it is under a lighter load and advances the timing to match the load it believes it has It works well because the ZX2 is ignition advance starved, just put a filter on it so you don't suck in dust.
Old 05-20-2012, 02:08 PM   #17 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
ill be in a zx2 5 speed here in a bout a week or so. my brothers been driving it and he says he gets around 29mpg and hes just light driving not hypermiling. I'm going to sell my intrigue and use the money to buy it off him for $800. It has a lot of new parts and i feel is a lot more reliable then my current car, gets better mpg's, and its a 5 speed =)
"The only real mistake is the one from which we learn nothing."
- Henry Ford
