Old 11-30-2012, 07:55 AM   #101 (permalink)
I happened to already have the door lock actuator, so all I needed was an h-bridge.
Options are always good though!
Old 12-03-2012, 12:04 PM   #102 (permalink)
I worked on the grill block a bit over the weekend. If I do say so, I think its turning out pretty nice.
The first thing I did was tweak the side angle pieces lengths so they were very close (about 1/32nd difference). You don't have to do this, since you could just cut the slats to adjust, but I wanted to. Next, I drilled the holes in the side angles for the rods to go through. I positioned these as close to the angle wall as I felt comfortable so the block doesn't have a big recess in it.
Next up was to cut out the coroplast grill slats. The only trick to doing this is cutting them large and trimming them down to fit nice.
One of the slats will overlap the other. This will help seal things a bit better while they are closed. So far it seems to fit together pretty good.
The next step was getting the steel rods bent up. I calculated with 1" of linear throw (which is what the door lock actuator provides), I would need the arm length (from centerline to centerline of the steel rod) to be .7" in length to get 90 degrees of rotation. I got it pretty close.
The last thing I worked on was the plate that connects the two rods. I just took a leftover piece of the aluminum angle and cut it up into a rectangle. Then I drilled two holes the same distance apart as the holes on the side angles. This plate is what the pushrod will attach to, and the pushrod will then attach to the actuator.
ID:	11981   Click image for larger version
ID:	11982   Click image for larger version
ID:	11983   Click image for larger version
ID:	11984   Click image for larger version
ID:	11986   Click image for larger version
ID:	11987   Click image for larger version
ID:	11988   Click image for larger version
The Following 7 Users Say Thank You to Daox For This Useful Post:
christofoo (11-17-2013), Leinaad (08-16-2018), mcrews (12-07-2012), nemo (12-03-2012), SoobieOut (12-03-2012), WD40 (12-03-2012), WesternStarSCR (12-03-2012)
Old 12-03-2012, 12:43 PM   #103 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
Awesome .. I am looking forward to see the end result, so I can copy it.
2000 Insight MT 106K Citrus A/C
Old 12-03-2012, 01:47 PM   #104 (permalink)
Haha, thanks. I'm very happy with it thus far.
There is one thing I'd appreciate some help with though. The rods are a little loose in the coroplast. So, they have to be fixed to it somehow. It would be great if that method was adjustable so you could more easily get everything setup, slats to seal better, etc.
My initial thought was to cut a groove in the back side of the coroplast in a couple spots. Just a short 1/4" cut or so to expose the metal rod. In that slot I could put some glue into the groove to lock the rod to the coroplast. However, this isn't adjustable, so you'd have to be sure its where you want it before you glue it.
My second thought was to take another small piece of aluminum and tap it for a setscrew. Then, I'd cut a groove in the coroplast to expose the rod like the above idea. The aluminum piece could be glued to the coroplast and then you could tighten the setscrew against the rod to lock it in place. I'm just not sure what kind of glue would work all that great to hold aluminum to plastic. It also requires a tap which not everyone probably has laying around.
Ideas are welcome.
The Following User Says Thank You to Daox For This Useful Post:
Old 12-03-2012, 06:17 PM   #105 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Ideas are welcome.
Would it be possible to mount it like a carburetor throttle plate, putting the screws through the metal tab and in to the rod. If the rod was ground down in those areas it would make a no slip mount.
PS
To avoid tapping the rod , it might be possible to just drill it and put a screw with lock washer and nut. If the one side needs to be smooth , it could be counter sunk on one side.
Old 12-03-2012, 07:25 PM   #106 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
have you the ability to center drill a couple holes through the steel rods? If so 2 holes in each (at the 1/3 and 2/3 of the coroplast lenghts) then smaller rod insertend through the holes and then zip tie the corplast to the smaller rods.
If you can not center drill use the same diameter rod, use a file to make interlocking notches, then drill from the flat side on each and use a small bolt or stainless wire to "Lash" them together.
to centerdrill with out a jig you can file a small flat (slightly smaller than the size of the drill bit) then centerpunch on the flat.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 12-03-2012, 07:48 PM   #107 (permalink)
EcoModding Lurcher
mort's Avatar
Ideas are welcome.
If it were me, I'd glue the coroplast to the actuator rods to provide the best range of movement. I'd make adjustments in the linkage to the lock actuator. The length of a connecting rod can be adjusted, like by bending a kink more or less sharply, to get exactly the right action.
Also this looks beautiful!
-mort
Old 12-03-2012, 07:50 PM   #108 (permalink)
Unfortunately, the steel rods are only 1/8" in diameter. I don't think I'll be tapping or drilling into them.
Old 12-03-2012, 07:54 PM   #109 (permalink)
Busting Knuckles Often
Blue Maxx - '04 Chevrolet Malibu Maxx LT
Team Chevy
90 day: 26.96 mpg (US)
Tink's Van - '08 Chrysler Town & Country Touring
90 day: 19.09 mpg (US)
2004 5 Speed Goldrolla - '04 Toyota Corolla CE
90 day: 36.3 mpg (US)
How about DECOUPLING each shutter axis from its bent linkage end
My thought was to keep your 'axle' and your bent linkage separate. This way, you can glue the axle to your plastic.
You leave some space at the linkage end, to slip one side of a double coupler to it. Now you attach the other end of set screw coupler to your bent rod.
This way, the axis of the shutter and the continuation of it are adjustable and can separate.
Your Axle of each shutter can then be glued good, with no worry about linkage position, it can be rotated and locked into place as needed.
The coupler would be like a small bit of round hollow aluminum, with a 2 set screws, one towards each end, to lock upon the steel rod.
Set Screw Shaft Couplers
Like this but you can make your own or find them cheap?
Hence, micro size decoupling "Smart shutter axle thing..."
My reference theory
Picture an anti-sway bar. Now picture the straight center of it versus the bends that mount it. You want to be able to rotate the 2 of them independently but lock them at correct spot.
Decoupled for off road use, coupled for on road stability. American Axle calls it a Smart Bar.
SmartBar™ Electronic Stabilizer System | Chassis System Components | Product Portfolio | American Axle & Manufacturing
The Following User Says Thank You to WesternStarSCR For This Useful Post:
Old 12-03-2012, 08:12 PM   #110 (permalink)
nemo's Avatar
Great frame design, so simple. Looking forward to seeing the progress.
I am toying with the idea of build a set of these my car (will need right and left), but I think here in the south they would need to run in the open position a significant amount of the time. From a drag stand point would it be better to pivot the slats from the top or bottom edge, so when open the slat doesn't extend out past the front edge of the frame?
actuated, ardunio, automatic, grill block
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 05:16 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
another project idea: electronically controlled grill block rjacob Aerodynamics 3 07-10-2008 04:36 PM
