Old 08-07-2013, 03:36 PM   #11 (permalink)
I know he explained the aluminum was a backing but if you're going to do all that I wonder what purpose the lawn edging serves.
Old 08-07-2013, 03:38 PM   #12 (permalink)
I'd agree that it's overkill, but I only got 3-years out of mine, and that was with repairing it with foil tape.
Old 08-07-2013, 03:40 PM   #13 (permalink)
There must be different flavors of lawn edging because the stuff I have is totally rigid enough for the job all by itself.
Old 08-07-2013, 03:42 PM   #14 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Misleading?
Right, because some reading is required - I get it.
hey, frank lee made the same mistake
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 08-07-2013, 03:50 PM   #15 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
I've no reason to believe that any of my lawn edging air dams have appreciably deformed at speed, but hey- if it's overbuilt it will last you longer.
My Civic's air dam is literally less than three inches off the ground and it's still hanging on. It scrapes on everything.
Old 08-07-2013, 03:50 PM   #16 (permalink)
Her are some more pics.
Here you can see my basic construction using aluminum and sheet metal screws. It is very ridged, feels sturdy enough to where none of its problems should be caused by wind. Only weighs about 2 pounds.
This is my first attempt at Mig welding aluminum in about 8 years.
This is what it looks like removed from the truck.
And with a coat of primer and truck bed liner.
ID:	13577   Click image for larger version
ID:	13578   Click image for larger version
ID:	13579   Click image for larger version
Old 08-07-2013, 03:53 PM   #17 (permalink)
If only that corner was radiussed, I'd say you would be done.
http://ecomodder.com/forum/showthrea...ing-17399.html
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
Cd (08-09-2013), Sven7 (08-07-2013)
Old 08-07-2013, 04:09 PM   #18 (permalink)
davelobi's Avatar
CRX - '91 Honda CRX HF
Last 3: 63.1 mpg (US)
the ugly one - '97 saturn SL just sl,not sl1 or 2
Team Saturn
90 day: 44.15 mpg (US)
Vibe - '07 Pontiac Vibe
Team Pontiac
90 day: 44.24 mpg (US)
Hoopdie - '05 Toyota Corolla CE
90 day: 42.58 mpg (US)
here is my lawn edging.
Worked out pretty nice.
I sure don't think it needs any backing.
Good thing it gives, car so low that some driveways get me.
Even those haven't hurt it yet.
Get bored very quickly. Vibe, Saturn, and crv all long gone. Been a while but I'm back in the game, gunna see what I can do with this Corolla.
Old 08-07-2013, 05:05 PM   #19 (permalink)
Maybe I should have mentioned I wanted to drop the air dam down 9 inches, leaving me with about 7.5 inches of ground clearance.
The lawn edging gives a little more than 5 inches when I cut the square end off.
ID:	13582   Click image for larger version
Old 08-07-2013, 06:26 PM   #20 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
Did you make sure your air dam is only as low as your lowest suspension component?
otherwise, if your airdam is too big, any FE gains would be cancelled out due to having increased frontal area. You'll know for sure if you play with different air dam sizes.
aluminum, lawn edging, pvc, wtf
