Old 04-11-2009, 08:50 PM   #1101 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Dashboard mayhem!
I saw something a while back I thought was pretty cool.
In a friend's EV, his odometer only showed the EV miles! (about 800 or so right then)
Since I am planning on trying to eventually mount some nice looking meters, maybe it was time to take the dashboard apart. (Especially since there isn't even a controller in my car right now!)
I yanked out the instrument panel and yanked out the speedometer.
Note to self - the car had this many miles on it.
It looks like I should be able to pop out both the gas meter and the temperature meter and replace them with volt meter and ammeter or some other useful instrumentation.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 04-11-2009, 11:38 PM   #1102 (permalink)
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Oldsmobile Intrigue GX
Last 3: 25.94 mpg (US)
Neat! I used to reset new odometers to match old ones that had messed up, back when I worked for the GM dealership. We had to be careful to match numbers, and certify correctness, to avoid problems with any future sales of the cars, since they all were less than 10 (or however many it was) years old.
If it isn't back in the car yet, you ought to figure out how many EV miles you already have on it, and reset the odometer to that. Just for the neatness factor and all...
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
Old 04-12-2009, 09:51 AM   #1103 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
I really didn't do a good job at all tracking my EV miles so far. It would have been a lot easier if I had a trip odometer.
That's one reason I thought it would be cool to reset the odometer. It would always be showing me all my EV miles!
My YouTube Videos
Old 04-12-2009, 11:25 PM   #1104 (permalink)
2004 Prius Owner
lectruck's Avatar
Cool
Didn't the original craigslist add have a 140,000 miles or was that just a rough estimate? Was in on your original reciept?
Old 04-19-2009, 09:28 PM   #1105 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Metro has 51+ OFFICIAL EV MILES on it!
My YouTube Videos
Old 04-19-2009, 09:41 PM   #1106 (permalink)
MAD Modder
Watch out, it looks like you are out of gas, and overheating
Just kidding. How long did it take you to put that on? One trip?
Old 04-19-2009, 10:03 PM   #1107 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Actually, all the indications are that the car is using NO GAS and it's a HOT car!
I have jokingly talked about rigging up those gauges to potentiometers to "dial-in" whatever I want on them. Otherwise it might be possible to connect them to something else. For example, have the gas gauge connected to a volt-meter so that the gas gauge shows the relative capacity of the battery pack.
I also measured the frame around the two side gauges, and they are just a little bit too small to remove them and replace with standard 2" volt and amp meters.
My YouTube Videos
Old 04-19-2009, 10:43 PM   #1108 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Electro-Metro VS CitiCar
My YouTube Videos
Old 04-19-2009, 11:22 PM   #1109 (permalink)
Christopher Jordan's Avatar
White Whale - '03 Chrysler Town & Country mini van all white
Congrats Ben! My City-el has a much easier to read bicycle speedometer. When I checked 'distance' it fad a disappointing 48 miles. I went about 5 miles and back. When home I checked again- 48 miles.
Had to measure distances, days used, multiplied for the time I owned it. Wish I had your patience! I am sure your temperature gauge would have been very accurate if measuring my forehead!
Old 04-19-2009, 11:29 PM   #1110 (permalink)
oops! had Had HAD!!!
electric car, electro metro, geo, metro
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 36 02-11-2015 11:08 AM
Daox's 1997 Paseo Build Thread Daox EcoModding Central 241 11-12-2013 11:23 PM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 26 12-16-2009 04:31 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Margo II: the build (project thread) AndrewJ Alternative Transportation 26 04-23-2008 01:23 PM
