Old 02-24-2013, 10:54 AM   #11 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
WEIGHTS:
Previa 3755 lbs, Sienna 3800 lbs
Odyssey 95-99 3450 lbs, '99+, 4250 lbs
Caravan 3457 lbs
Venture 3655 lbs
Astro 4427 lbs
Silhouette, 1990-1995 3460 lbs
Liters/min@65mph
Caravan 2.5*2000 = 5000
Venture 3.4* 1300 = 4420
Astro 4*1800 = 7200
Odyssey 2.2*2300 = 5060
silhouete 3.1*1350=4185
payload: lbs
Astro 1430 lbs
Venture 1450 lbs
caravan 1200 lbs
previa 1400 lbs
Odyssey '95-'98, 1250 lbs, '99+, 1700 lbs
Lumina APV, Trans sport, sillhouette 90-96 1250 lbs
cd, cda, m^2:
Astro .38
Previa .35, 1.12 , Sienna, .32
caravan, '95 .39, .'98,.35
Venture, .34
Odyssey,1='95.35, '99.30
Old silhouette 1990-1995 .30
The Astro wieghts 1000 lbs more than the Odyssey. There is an Odyssey on Craigs list that I called on.
- Tony
Old 02-24-2013, 11:45 AM   #12 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
Transit it too tall, and it's a Ford, and it's too new. I only buy old cars.
- Tony
Old 02-24-2013, 12:04 PM   #13 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
Originally Posted by pete c View Post
Yes, the Nissan V-6 in that villager is one of the best damn motors ever made. The 3.3 dodge is a damn good motor as well, unfortunately is was bolted to a POS AOD tranny. Dodge has seemed to finally iron out the problems with this tranny. I had an 02 GC with this drivetrain that shifted like new the entire time I owned it. I believe the cure was a monster sized tranny cooler. I became very familiar with it after my daughter stoved in the front end and I got to replace it all. The cooler was approximately the size of the AC condenser.
Chrysler engineers decided not to have a gasket on the valve body, this would eventually leak and cause hunting, shifting problems and then clutch failure. A friend had a caravan and replaced the transmission 4 times, every 50k it would go out.
- Tony
Old 02-24-2013, 12:06 PM   #14 (permalink)
vacationtime247's Avatar
The Toylet - '87 Toyota Supra 350 Chevy V8 / 700R4
In-Durrrr-Oh - '09 TMEC Enduro TMEC 200cc Enduro
90 day: 60.9 mpg (US)
Tem-poo - '86 Ford Tempo GL 4 Door 2.0 Liter Diesel 5 Speed
90 day: 47.52 mpg (US)
Ass Tick - '01 Pontiac Pontiac Aztek GT 5 Door
Green Baby Poop Stain - '01 Pontiac Aztek Aztek Base Model
Black Track - '01 Pontiac Aztek GT
I know it's not necessarily a minivan, but I've got pretty good fuel mileage out of my Pontiac Azteks. Much better than most SUV's. On my trip out west this last summer, I was averaging around 25 mpg. Mostly highway & interstate. This with 4 people and the rear loaded down with camping equipment.
VT247
Old 02-24-2013, 01:04 PM   #15 (permalink)
^First anecdotal evidence that the Aztek "fastback" is slipperier than squareback vans?
Old 02-24-2013, 01:25 PM   #16 (permalink)
You can look at the Aztec as a slippery minivan. i look at it as a bloated hatchback and quite possibly the ugliest damn thing to ever roll down the road.
To me a minivan means 3 rows of seats and relatively easy access to all of these. And relatively easy movement between the various rows. Also, all the seats can be removed/stowed to make a big cargo area.
The Aztek does not meet any of these requirements.
And did I mention it is fugly? If I had any use for an overgrown hatchback, I'd rather have the buick version.
Old 02-24-2013, 01:36 PM   #17 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
The Miles ZX40 minivan is probably the best, uses no gas at all.
In seriousness though the newer generation Daihatsu Move varieties (including the Mira, and others) top out around 50mpg at reasonable speeds. (CVT oddly enough)
Sure they are small but they are a mini van, really not a car per se.
Old 02-24-2013, 05:37 PM   #18 (permalink)
Some nice minivans for ecomodding are the good old Chevrolet Lumina APV/Oldsmobile Silhouette/Pontiac Trans Sport, 1st-gen Mazda MPV and the Ford Aerostar.
It's not impossible to adapt the 4-banger Iron Duke bolted to a 5-speed manual into the Lumina APV, I've already seen one configured this way.
1st-gen Mazda MPV and Ford Aerostar, due to the RWD layout, also allow a wide range of engines to be retrofitted into, including some small Diesels such as the Kubota V2203 which is getting some popularity among Chevy S10 and Ford Ranger owners, with different gearings also possible to select and maximize the overall efficiency.
stillsearching (05-19-2013)
Old 02-24-2013, 07:33 PM   #19 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
I am not particularly fond of Aztecs. The Odyssey was sold within an hour, $700 :C Thinking of generation 3 or 4 dodge with 2.4L I4 engine and swapping in a neon 5 speed. I don't like the Iron Duke engine, too over square, EcoTec I4 isn't bad.
- Tony
Old 02-24-2013, 07:56 PM   #20 (permalink)
90 day: 51.82 mpg (US)
You're on the right track: anything with a manual should be top of the list. Or added to the list if you're willing/able to do a swap.
I'm not sure what a stock Mazda 5 is capable of, but the stick sure gives you a lot more options when it comes to technique.
