07-13-2021, 04:55 PM
#21 (permalink)
OP wasn't kidding at Permalink #10. We're discussing amongst ourselves.
That said my Lexus axle has 6.78 to 1 reduction and it's capable of 10K RPM. 8 to 1 on a 5K RPM capable motor might be a problem-o.
Lol, he never even made it to the magical 5 posts!? What a terrible bot.
07-13-2021, 05:01 PM
#22 (permalink)
He could be a member or a former member, with a burner account... 😉
You never know...
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
07-13-2021, 05:17 PM
#23 (permalink)
home of the odd vehicles
As previously stated no big loss,
I believe this guy had a similar reaction on diyelectriccar
8:1 ratio with ??? Big tires and a 12kRpm + leaf motor would not be rpm limited
The Following User Says Thank You to rmay635703 For This Useful Post:
07-13-2021, 06:36 PM
#24 (permalink)
Wasn't sure I didn't have the ratios backward.
Given the superior gearing available for the rear he could proceed to obtain a Caddillac FWD V8 transaxle (preferably 5mt) and then install an 11” Nissan Leaf A/C motor controller and battery using the universal inverter hack face mounted citicar style straight to the face of the 8.x rear pumpkin.
Needs a picture. Here's one or two that would satisfy his 10 MPH creep function:
.tragectory: Line goes down and to the right.
07-13-2021, 08:18 PM
#25 (permalink)
Neither stated clearly his goals at Permalink #1.
Maybe someone else would have an actual, and eventually better, use for this matter anyway.
The Following 2 Users Say Thank You to cRiPpLe_rOoStEr For This Useful Post:
07-14-2021, 11:04 AM
#26 (permalink)
Moving the bar forward but actually caring about what's cost effective, wouldn't a normal gearset in the front of a 4wd truck (say 4.10:1) be sufficient for 10 mph?
I personally would want more like 65 mph possible or what's the point of dragging around 100s if not 1000 pounds of extra gear.
The added generator is also a bad idea. The ICE motor is the already 10 times more powerful generator.
I did see on the Jeep 4XE (supposedly the #1 selling PHEV last quarter) you can turn on and off the EV modes saving the battery for when you want, or put it in a generator mode where it adds to the charge. Pretty cool. And it runs 8.8 sec 1/8 mile drag racing although the guy did pull out the rear seat and spare tire (common drag racing hacks.) That's generation 4 or 5 Corvette territory. I bet 0-60 it would probably beat the c5 vette as the 1/8 mile is more like 0-75 mph.
https://youtu.be/Reo57YMcH_0
07-14-2021, 07:31 PM
#27 (permalink)
Considering how most commercially-available full-hybrids already resort to the electric motors as generators too, this would be quite overkill.
07-15-2021, 06:17 PM
#28 (permalink)
The d!ck in me hates to side with the OP just on principle, BUT electric power produced by the ICE motor is likely to be brutally inefficient, especially at idle. He's talking about powering household/workshop type items, and a generator is the right choice.
Pulling 2000W out of a V8 idling is going to burn WAY more gas than pulling 2000W out of a 4000W generator.
A typical 4000W generator has a ~200cc engine vs. 5000cc of a 5.0L truck ICE (are there any that small? Mine is 7.4L). LOTS of fuel goes into just keeping the 5.0L mass moving, and it's going to have very high mass flow through it.
The most sensible way to make power using a generator is to size the generator such that the typical continuous run load is 70-80% of the maximum.
The Following User Says Thank You to S Keith For This Useful Post:
07-15-2021, 11:59 PM
#29 (permalink)
Well if you have say a 10kwh battery you don't pull just 2000watts out of a generator. You pull as much as possible and charge the battery, then shut off the ICE and use the battery, repeat. Normally you would want to size the generator to the load, but with the battery you can make that the big load and then bleed that with the usage.
07-17-2021, 11:01 AM
#30 (permalink)
In the way the OP wants to create a "hybrid" probably so, but an engine designed for hybrid use is much better designed and tuned to work as a generator because that's what it is for.
