Old 08-31-2010, 10:13 AM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Big test of 5 LRR tires
With low RR tires becoming mandatory in Europe as of November 2012 (earlier in new cars), a recent issue of the Polish edition of Auto Bild (Auto Świat 34/783, 16.08.2010) published a test of five low rolling resistance tires: Bridgestone Turanza ER300 Ecopia, Goodyear EfficientGrip, Michelin Energy Saver, Nokian V, and Pirelli Cinturato P7. The tested tires were all 205/55R16, and were tested on a Mercedes C200 CGI, loaded with precise instrumentation, on a flat test track with no wind. All showed a reduction in fuel consumption compared to the standard tire (the article doesn't reveal what the standard tire is in this case). Fuel consumption was measured at three different speeds: 80, 100, and 130 km/h (50, 62.5, 81 mph).
FEl/100kmmpg(US)
Michelin6.7235.00
Goodyear6.7434.90
Pirelli6.8734.24
Nokian6.9134.04
Bridgestone7.0833.22
standard7.3432.05
Fuel consuption was not the only thing tested, the main focus was safety.
First, the maximum aquaplaning speed.
speedkm/hmph
Nokian85.853.6
Bridgestone85.253.2
standard85.153.2
Pirelli83.352.1
Goodyear81.851.1
Michelin78.549.1
Aquaplaning on a curve:
lateral accelerationm/s2ft/s2
Bridgestone3.5311.65
Pirelli3.3511.06
standard3.3010.89
Goodyear3.2810.82
Nokian3.2610.76
Michelin3.019.93
Driving on dry pavement:
speedkm/hmph
Bridgestone100.662.9
Michelin100.662.9
standard99.962.4
Pirelli99.862.3
Nokian99.462.1
Goodyear99.262.0
Driving on wet pavement:
speedkm/hmph
standard82.351.4
Pirelli81.651.0
Bridgestone79.549.7
Nokian79.449.6
Goodyear77.748.6
Michelin75.947.4
(Note: In this test the car was very hard to control with ESP on when fitted with Michelin and Goodyear tires.)
Braking on dry pavement (from 100km/h, 62.5mph):
distancemft
Bridgestone36.5120.5
Goodyear37.0122.1
standard37.0122.1
Michelin37.3123.1
Pirelli37.3123.1
Nokian37.9125.1
Braking on wet pavement (from 100km/h, 62.5mph):
distancemft
Pirelli57.6190.1
standard57.8190.7
Nokian59.7197.0
Bridgestone59.8197.3
Goodyear62.1204.9
Michelin64.7213.5
Driving in a circle (time for one lap, article did not give radius):
times
standard22.59
Bridgestone22.73
Pirelli22.86
Nokian22.96
Goodyear23.15
Michelin23.18
Rolling resistance (measured on a special machine):
Goodyear7.83
Michelin7.87
Nokian9.01
Pirelli9.67
Bridgestone10.13
standard11.90
External noise (average of tests @ 70/80/90 km/h; 44/50/56 mph):
noisedB
Bridgestone71.5
Pirelli71.7
Nokian71.9
standard72.0
Goodyear72.7
Michelin72.7
Summary: The best low RR tire appears to be the Pirelli Cinturato P7, with Bridgestone Turanza ER300 Ecopia second and Nokian V third. Goodyear EfficientGrip and Michelin Energy Saver may have the lowest rolling resistance, but their performance is at the lower boundry of safety.
Note: The article did not give details about the testing procedures, i.e. how many tries were averaged, etc. I pretty much translated the whole article, plus converted all units.
The Following 17 Users Say Thank You to Piwoslaw For This Useful Post:
akcapeco (10-26-2010), ausias (03-01-2012), euromodder (08-31-2010), Frankencar (05-02-2012), gone-ot (08-31-2010), hate2loveford (01-22-2013), JacobAziza (05-04-2012), LeanBurn (05-04-2012), mcrews (03-01-2012), mechman600 (03-17-2013), mort (03-01-2012), Nevyn (09-01-2010), Patrick (08-31-2010), TheMarkofPolo (05-03-2012), TOOQIKK (07-17-2011), vtec-e (09-01-2010), wmjinman (01-10-2013)
Old 08-31-2010, 06:54 PM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Piwoslaw View Post
Driving on dry / wet pavement:
What do they mean by that ?
Just "driving" doesn't say much
That's exactly where I'd put the Energy Saver, especially because of its wet weather performance (or rather lack of it).
It's OK in the dry though.
I also use the wider 205 16" version, rather than the stock 195 15" .
Driven acording to ecodriving / hypermiling principles, you shouldn't get into trouble.
I've removed the original Energy 3 B (I think, could have been E3A) from the car because of their lousy performance - the wider Energy Saver is notably better than that.
Old 08-31-2010, 07:15 PM   #3 (permalink)
Did they mention what air pressure(s) they used?
Old 09-01-2010, 03:48 AM   #4 (permalink)
aero guerrilla
Piwoslaw's Avatar
Like I said, there aren't too many details about the testing procedure, so I'm guessing this means some kind of zigzag-shaped driving course.
No. At first I assumed that each tire was at the door sticker suggested pressure, but there was a comment that more or less stated that
The higher pressure, which reduces rolling resistance, also reduces comfort. Of the tested tires, Goodyear had the best ride comfort.
This would imply that the LRR's had a higher pressure than the standard tires. This would be weird, as I haven't seen LRR tires that have higher max sidewall pressure than similar non-LRR tires of the same size. I'd like to see a test of the standard tire with higher pressure, then not only would its RR be lower, but it would also allow a high aquaplaning speed and shorter braking distance (see "Inflation pressure does not affect grip": Autospeed article), making it compareable to the LRR's.
Old 09-01-2010, 05:04 AM   #5 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
Ah yes, but from what we've all seen here, sidewall pressure is taboo in the mainstream world. I'd say they run them at a slightly higher pressure but only by a few psi. There is no way they would recommend sidewall pressure and even if the tire had a sidewall max of 60psi they still wouldn't recommend 40 or 50 psi. As i've said, it's a taboo subject!
But yeah, i totally agree with you. Higher pressure would reduce aquaplaning and even out treadwear. But that would reduce the amount of tires we'd have to buy and we can't have that!
ollie
The Following User Says Thank You to vtec-e For This Useful Post:
kYLEMtnCRUZr (10-11-2014)
Old 03-01-2012, 01:58 PM   #6 (permalink)
Burning oil to move air.
ausiasmobil - '06 Seat Leon 1.9 TDI Reference
90 day: 40.22 mpg (US)
EcoTxec - '99 Skoda Octavia 1.9 TDI 110 cv Laurin & Klement
90 day: 52.85 mpg (US)
REmember this post:
http://ecomodder.com/forum/showthrea...-db-18989.html
It also contains data from tires from "official" tests.
I would add to your data also:
http://www.goodyear.eu/de_de/images/...ive-report.pdf
TUEV SUD report on:
TÜV SÜD Automotive Tire Benchmark Test -2009205/55 R16 91 V: Wet & Dry Performance -Lifetime -Rolling Resistance/Fuel EconomyReport No. 76236753-2
Bridgestone Turanza ER300, Continental PremiumContact 2, Goodyear EfficientGrip, Michelin Energy SAver, Pirelli P6 Cinturato Ecoimpact.
autobild sports car test
http://www.carworks.gr/online/pdf/hankook_autobild.PDF
http://www.unigum.pl/images/stories/...65_R15_91H.pdf
http://www.bettertyres.org.uk/_uploa...yre%20test.pdf
i have more data on pdf but i can't attach it because of kB limits in this forum, sorry
Official tests and documentation from European Comission lots of info (there is important info hidden in the zips and endless and boring documents ): radius dependance of tire rolling resistance, rolling resistance of large sports tires being better than small "eco" ones, etc. all the test are anonimously so make and model comparision (or brands: van, car eco, car uhp, etc.) couldn't be done but its interesting.
http://ec.europa.eu/energy/efficienc...f_tyres_en.htm
http://ec.europa.eu/energy/efficienc...g_tyres_en.htm
where you could find these working documents and analyses of tires, summary from independent test with assessments on specific tires (with make and model), etc:
http://ec.europa.eu/energy/efficienc..._documents.zip
Sold:
The Following User Says Thank You to ausias For This Useful Post:
Piwoslaw (03-03-2012)
Old 05-03-2012, 07:30 PM   #7 (permalink)
GTI TDI - '91 Volkswagen Golf GTI
Diesel
90 day: 61.23 mpg (US)
This is great information! thanks! I plan to run a set of the Pirelli P7 Centurato tires on my GTI - see if I can get the average up to 66 mpg.
Old 05-04-2012, 08:03 AM   #8 (permalink)
Tire Geek
CapriRacer's Avatar
I find it really interesting that they document that wet traction is worse for the LRR tires.
Old 05-04-2012, 11:05 AM   #9 (permalink)
euromodder's Avatar
Why ?
It's almost a universal feature that LRR tyres perform less well in wet conditions.
Old 05-04-2012, 12:07 PM   #10 (permalink)
Interesting, but I'm quite puzzled by one comment:
I've never found ESP to be a very good way of controlling a car, though it would be very useful for avoiding some of the other drivers on the roads, who do seem to be driving by ESP :-)
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 276 03-14-2022 03:51 AM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
Book:The Car That Could [making the EV-1] cfg83 Aerodynamics 12 09-17-2010 02:12 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
stock tire sizing question ratherbehiking Off-Topic Tech 11 04-06-2009 11:53 PM
