Old 04-03-2010, 08:44 PM   #21 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
Just ordered a set of Yokohama AVID TOURING-Ss. Someone on a Prius forum I found reported an extra MPG above the OEM Integritys, and I bet they'll be MUCH better than my Wal-Mart specials Douglas XtraTrac IIs I have now.
They're also rated at 51 PSI max, much better than my current 44.
In Reason we Trust
Old 04-14-2010, 09:12 PM   #22 (permalink)
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
Yoko Avid's are what I am buying too...
I have used them before. Did 205/75-15's on a '97 Camry for approx 9.25% over size on diameter.
At a mere 40lbs they were firm enough to get 35-36 on the Camry, great wet traction, decent light snow and OK dry traction. They were quiet too.
Inflated to 50 the solid line tread down the middle of tire makes for pretty good LRR tire.
I will be doing 205/70-15, approx 6% oversize from stock 195/70-14's.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
Old 04-15-2010, 02:41 PM   #23 (permalink)
AeroModder's Avatar
Team Ford
What kinds of gains did you see when you switched? My last tank (and first with the new Yokos) surprised the heck out of me, even with some full-throttle acceleration at the local drag strip. I was going to test some intake setups, but something didn't sound right on the second pass, so I called it a day. Even after all that, I got 26.4 MPG. I'm planning on reworking my front air dam to reduce the frontal area and meet with the front undertray, so that could push me above my 30MPG goal.
In Reason we Trust
Old 04-15-2010, 09:42 PM   #24 (permalink)
Nokian is about to release a new model, called the eNTYRE:
Old 04-16-2010, 01:48 PM   #25 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
eNTYRE Marketing stuff:
Working from its winter experience, the asymmetric eNTyre features a number of traction and safety characteristics, including 3D sipes, polished grooves and five circumferential grooves for hydroplaning resistance, a “splash stopper” feature to reduce on-road splatter, and ultra low rolling resistance, and a new tread compound for all-season traction and high mileage.
The tire will be available in the first quarter of 2010 in 26 T-, H- and V-rated sizes covering 15- to 17-inch wheel diameters. eNTyre sizes in 15- and 16-inch carry a UTQG of 700AA, while the 17-inch sizes are rated at 560AA.
Those are some good wear ratings. Too bad I can't get them in my size.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 04-30-2010, 12:16 PM   #26 (permalink)
Camry MPG Modder
OK,
results from 649 mile run. 18.03 gallons for 35.8 MPG.
So far I have only installed the front 2 tires. (Yokohama Avid S 205/70-15's approx 6+% oversize.
And this trip included more local driving, 1/2 hr of stop and go interstate traffic and 1/2 hr of right or left lane closed slow downs. Its repaving season.
My RPM's are down. Now when speedo reads 65, actually like 68+ rpms are down to around 2600 instead of 2800.
It definitely took its toll on low speed(60-65) hill climbing though. At 60 rpms get down to below 2400 and it took a lot more throttle to maintain speed.
Sweet spot is at 16-17 tps(Throttle) on level grade at 65-70mph. MAP goes below 8.0, even down to high 6's to mid 7's and mpg on Scangauge hits high 30's to low 40's.
I really need to get the rear tires on, may need spacers, and get to work on aero mods to reduce HP/torque load at why speeds.
Pete
Old 05-04-2010, 02:05 AM   #27 (permalink)
Camry MPG Modder
Got all 4 on now...
Back tires clear the bottom on the strut house by about 3/8 inch.
Tomorrow I will embark on a 500-600 mile 2 day journey to/fro work.
Will top off tank, top off tires at 44 front 40 back.
4 hrs of driving at a time I cant take too rock solid tire pressure.
http://www.tirerack.com/tires/tires....omCompare1=yes
Pete
Old 05-04-2010, 10:18 AM   #28 (permalink)
...beats walking...
...but what are their LRR "numbers"?
...the stock OEM Goodyear Eagle RS-A's has LRR = 0.0092 value.
...wonder how much better the Nokian EnTYRE's might be?
Old 05-04-2010, 10:34 AM   #29 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
...the stock OEM Goodyear Eagle RS-A's has LRR = 0.00185 value.
You mean the coefficient of rolling resistance, CRR? Most tire companies don't publish those, unfortunately.
Also, the lowest CRR I've encountered is 0.006 for Potenza RE92's, 0.0035 for race bicycle tires.
Old 05-04-2010, 12:15 PM   #30 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
the only CRR for Nokian I have seen is for the discontinued NRT2 which was the number two tire in the green seal report @ .0085. I hope they have improved since then.
Highest on the list was .0152 and lowest was .0062 Bridgestone B381 185 70 R14
Greanseal's cutoff was .0105. I would say low would start below .009
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 46 06-05-2015 04:24 PM
155/80-13 tires (looking for LRR options) Daox EcoModding Central 69 01-10-2011 11:47 PM
What are the best LRR Tires ??? hypermiler01 EcoModding Central 1 10-08-2008 07:55 PM
FS: Set of (5) VX Rims with LRR Tires XFi For Sale 2 02-16-2008 02:49 PM
