Old 02-03-2009, 09:59 PM   #121 (permalink)
Bio Deezler (sold) - '03 Volkswagen Jetta GLS TDI
90 day: 50.78 mpg (US)
The Beast. - '03 GMC Sierra 2500HD SLT
90 day: 12.86 mpg (US)
No problem Dave. Thought more folks might chime in... guess no one cares, haha. Either that or I just nerded out hardcore.
Traffic on this site has been a bit slow since sub $2 gas came back, sadly. (gas tax NOW!)
Well I said I would post up my gear swap calculations, so here they are.
Available options for my TDI are 0.681 and 0.658 5th gear ratio sets. (Stock is 0.755). I have also been considering a set of 205/60/16 tires (3% more circumference vs the stock size of 205/55/16).
The combination of the .681 gear and the 205/60/16 tires is almost exactly equal to the effective overall gear ratio as the .658 gear set, btw.
So whereas we could place a mph scale atop the former graph since our gear ratio was unchanging, we can no longer do this. Instead, trusting that our aerodynamic and rolling resistance is constant at a given speed, despite the vehicle gearing situation, we can interpret vehicle speed as a constant power requirement. (e.g. the blue lines from before). So below I plotted 72.5 mph = 24.3 HP, and for a Cd of 0.27, 72.5 mph = 22.2 HP.
The green dot is our starting point. Changing the gear ratio with a .681 ratio 5th, and the 205/60/16 tires, we move from 2496 rpm at 72.5 mph in stock form down to 2189 rpm, along the 24.3 HP line. Finally I again looked at a coefficient of drag reduction down to 0.27, sticking with the new overall gear ratio. Estimating the BSFC for each point, these are my results:
mph rpm load(kW) BSFC est gal/h mpg
stock gear & tire 72.5 2496 18.11 263.0 1.480 48.98
0.681 gear 72.5 2251 18.11 248.5 1.399 51.84
0.658 gear 72.5 2175 18.11 243.0 1.368 53.01
205/60/16 tire only 72.5 2427 18.11 260.0 1.463 49.54
.681 and 205/60/16 72.5 2189 18.11 244.0 1.373 52.79
Cd=0.27 .681, 205/60 72.5 2189 16.54 248.0 1.275 56.87
So, I'm sold. I think I'll actually stick with the stock tire size and grab a .658 5th gear! I may not ever recoup the entire cost of the gear swap ($350 - sale of stock gear = ~$200). But the reduction in engine noise, wear, and fuel consumption are all worth money to me.
edit: stupid table formats never hold up during posting.
The Following 2 Users Say Thank You to Deezler For This Useful Post:
ausias (04-04-2013), kennybobby (09-12-2012)
Old 02-03-2009, 10:21 PM   #122 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Deezler -
Just to echo others, really great stuff. "Seeing" the gear on the chart is uhhhh-maze-ink.
(ha ha, it looks like battle plans on topo maps)
CarloSW2
American Solar Energy Society
Old 02-04-2009, 02:08 AM   #123 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
You can now make basic tables.
{table}{tr}{td}1{/td}{td}2{/td}{/tr}{tr}{td}3{/td}{td}4{/td}{/tr}{/table}
(using square brackets, not the curly ones) gets you...
12
34
(Space between here and table is due to line breaks in the table, remove those to eliminate.)
.mphrpmload(kW)BSFC estgal/hmpg
stock gear & tire72.5249618.11263.01.48048.98
0.681 gear72.5225118.11248.51.39951.84
0.658 gear72.5217518.11243.01.36853.01
205/60/16 tire only72.5242718.11260.01.46349.54
.681 and 205/60/1672.5218918.11244.01.37352.79
Cd=0.27 .681, 205/6072.5218916.54248.01.27556.87
The Following User Says Thank You to TestDrive For This Useful Post:
Old 02-04-2009, 08:24 AM   #124 (permalink)
Cool, thanks TestDrive.
Old 02-04-2009, 08:57 AM   #125 (permalink)
You're welcome.
Old 03-24-2009, 11:11 AM   #126 (permalink)
I prepare the graduation thesis of my master. I need bsfc maps and vehicle & engine spec as well. Could you please sent me? Thanks in advance.
Old 03-24-2009, 11:26 AM   #127 (permalink)
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
It will be on your desk by monday morning.
The Following User Says Thank You to Wonderboy For This Useful Post:
Old 03-25-2009, 07:14 AM   #128 (permalink)
thankS Wonderboy. I am waiting your e mail.
Old 03-25-2009, 09:59 AM   #129 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
Not sure if we're experiencing a cultural divide moment here, or simply counter-sarcasm.
Hafi: I don't think anyone has any additional BSFC information beyond what you will find by going through this thread.
Old 03-28-2009, 09:48 PM   #130 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
2.0 Ford Zetec BSFC
Ok, I've been digging thru the net trying to find a BSFC for my car. I think I found one, and a wealth of knowledge from this MIT paper: http://dspace.mit.edu/bitstream/hand...pdf?sequence=1
It's 115 pages, so don't start it unless you got some time It's quite in depth and covers many effciency topics including EGR dilution, NoX reduction, Lean Burn and Hydrogen boosted Lean burn. Quite in depth.
The first chart is the baseline without any EGR function, the second is with 10% EGR dilution and the third is with the Hydrogen boosted Lean Burn.
Enjoy!!!
Name:	2.0 Zetec BSFC map.JPG
ID:	3098   Click image for larger version
Name:	2.0 Zetec BSFC map 10% EGR.JPG
ID:	3099   Click image for larger version
Name:	2.0 Zetec BSFC map, Lean Burn.JPG
