Old 08-24-2015, 06:24 PM   #511 (permalink)
32 mpg pop up
Originally Posted by Miller88 View Post
I bought a popup camper. The idea was to get one that was small enough to tow behind my Focus.
Got 32MPG pulling the Popup empty at freeway speeds (65)
Yes,please,some dimensions would be great for a trailer database,since many of the RV sites are worthless for specific info.Thanks in advance!
Old 08-24-2015, 07:32 PM   #512 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
It seems that some of said sites dont like the fact that I am pulling a camper with a Ford Focus. I am supposed to buy a Brodozer-Elite with Max Bro package Platinum Laramie Lariat High Sierra Denali truck to pull my camper.
It is a 1987 Coleman Columbia. Weighs about 830 pounds dry. Focus honestly does not feel it other than on expansion joints. It is not much wider than the car and the top of it is only a few inches higher than the trunk. There isnt too much ofa negative affect on aerodynamics.
I planned to go pick it up with my Jeep but it broke down. Was not expecting the focus to 1) Pull it so well and 2) get good mileage.
The Following 2 Users Say Thank You to Miller88 For This Useful Post:
aerohead (08-25-2015), skyking (08-24-2015)
Old 08-24-2015, 08:07 PM   #513 (permalink)
aerohead—if someone is maintaining that database, I just learned about the https://www.google.com/search?q=fiber+stream+trailer
from a post on Go Away Garage
Old 08-24-2015, 09:17 PM   #514 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Nice pop up, Miller. We had an 86 coleman, but it was more like 2000 pounds, 12' and had a shower, etc. It was our first venture up off the dirt and we remember it fondly. It was quite a bit wider than yours as well, you would know about the aero drag in a narrower rig.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
Old 08-25-2015, 08:13 AM   #515 (permalink)
It now has a 4'' lift in it. Completely reversible in about an hour.
I lucked out by getting something this small. I was originally going to build a teardrop but I determined that to be too impractical. I love camping but I HATE tents. I'd rather sleep in the vehicle or sleep under the stars in a homemade shelter - have done both - before camping in a tent again. Ugh.
The problem with a teardrop is there is no room to store anything while camping. Plus trying to register it as a homebuilt.
I started to look at Popups. Originally was looking to find something in the 1200-1500 pound range because I didn't realize there were popup campers this small. It fell in my lap.
Interested to see how the focus does pulling it when it is loaded for a camping trip.
There are some weight reduction mods still ready to come. I plan on taking off the LP tank and the stove. The heavy wooden table will be replaced by a plastic one - unless I actually need the 3rd bed, that is - bearings have been repacked before I got it so not a lot of drag there.
The car will be getting airbags for the rear. I think if I were to raise the rear up it would also help a bit with aero. the other issue is the "control blade" rear suspension toes out like crazy when there is a lot of weight on it. It's definitely compressed with the popup attached to it, so I suspect there was a bit of toe-out. I didn't feel any more heat on the inside of the tires
The Following User Says Thank You to Miller88 For This Useful Post:
Old 08-25-2015, 01:17 PM   #516 (permalink)
Dark Egg - '12 VW Touraeg
As far as registering homebuilts, my idea was to make one a slide in like a pickup bed camper. The trailer would have to be registered but at least in my state, the slide in is free. I was going to use a 20' car hauler in my case and build a big, pop-up teardrop that would winch on and off. Then my plan was foiled by finding a $1000 hi-lo camper that basically did the same thing for the price of just the trailer.
Old 08-25-2015, 01:25 PM   #517 (permalink)
On a non-tow vehicle, the result of excessive rear toe-out would be squirrely handling, although a trailer in tow might mitigate that. The only people that seek that out are Gymkana racers.
Old 08-25-2015, 02:48 PM   #518 (permalink)
The aggressive rear alignment is what makes the Focii a good handler, even in stock form. This one burnt its rear tires off in short order from having excessive rear toe. It wasn't exceeding any factory specs, but it was right at the edge of it.
Old 08-26-2015, 11:38 AM   #519 (permalink)
That pop up trailer reminds me of my own camping trailer..
Towed behind my Citroën AX..
Like you said, no need for a big 4x4 or a pickup, towing a trailer behind a regular car is the worlds most normal thing over here in Europe.
The Following User Says Thank You to AlexanderB For This Useful Post:
aerohead (08-26-2015)
Old 08-27-2015, 08:36 AM   #520 (permalink)
The Durd (retired) - '96 Geo Metro
90 day: 53.79 mpg (US)
The Durd II (retired) - '97 Geo Metro
Redsight - '00 Honda Insight
Trailers are the way to go!
pickup, trailer
