Old 11-11-2011, 11:35 AM   #11 (permalink)
Originally Posted by silverinsight2 View Post
Cheaper hatch struts ARE available.
Where? I need to replace mine.
Old 11-11-2011, 01:52 PM   #12 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Before buying my Insight, I spent about six months researching battery issues with the car.
That said, I took the time to get a proper trickle charge setup in the car, and I now charge the battery nightly before heading off to work.
Take a look at the link below for details...
https://picasaweb.google.com/threewh...rickleCharging
After doing this, and starting to trickle charge nightly, the battery is vastly stronger, especially after the first 20 cycles or so.
I am finding that the battery likes ambient temperatures below 70F or so too.
Jim.
The Following 2 Users Say Thank You to 3-Wheeler For This Useful Post:
Tango Charlie (03-17-2012), Xist (12-28-2018)
Old 11-11-2011, 04:55 PM   #13 (permalink)
A few links...more available at Insightcentral
Brand New Lift Supports for your Insight Hatch - Insight Central: Honda Insight Forum
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
The Following 2 Users Say Thank You to silverinsight2 For This Useful Post:
Cd (03-17-2012), Xist (12-28-2018)
Old 03-17-2012, 10:14 AM   #14 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I have found two Insights for sale at a dealer around 75 miles from where I live now.
Both will most likely have a dead IMA battery - one supposedly has a ' fresh ' battery.
Besides a receipt from Honda on battery replacement, how can I tell if the battery has been replaced under warranty ?
One of the cars is more desirable to me simply because of the color : red versus the all too common silver.
This particular car red car has a stone dead battery pack. From what I have read, I should flip the main power switch to the battery pack to " off " if I plan to drive the car home.
I saw mention in one of the battery refurbish threads here of also cutting the wires to the pack if I plan to drive it for an extended drive.
That seems rather drastic , but will I damage the pack if I simply flip it to off and drive that way ?
Also, what can be expected in a car with a dead pack ? What dash lights normally come on and for how long ?
With a dead pack , what other things get broken ? Do you still get a working trip computer , tach etc
Im assuming the charge lights go nonfunctional.
How does the car behave . There is no stop start function so I was wondering if the car runs like a normal car at stoplights or if it trips over itself sometimes. I have read the car becomes extremely sluggish with no pack. How sluggish are we talking here ?
Old 03-17-2012, 07:08 PM   #15 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Bump
Old 03-17-2012, 09:03 PM   #16 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Bumpety bump ( please ? )
My Civic is having random electrical problems and I'm considering an Insight as a replacement.
Old 03-18-2012, 12:09 AM   #17 (permalink)
Cd
Ultimate Fail
Cd's Avatar
How hard is it to repair aluminum body panels like the insight has ( versus steel ) ?
What all is steel on the car ?
Old 03-18-2012, 12:31 AM   #18 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
My guess is that they are probably on par... in some ways, aluminum might be easier to repair. Aluminum would definitely be more expensive to replace, though. The good thing is, it won't start to rust through chipped paint/exposure to the air.
Old 03-18-2012, 04:16 AM   #19 (permalink)
Run the vin thru a Honda dealer
CUT NOTHING...Turn the rear breaker switch off, remove the big battery lid ( T30 and 10mm... DANGER, HIGH VOLTAGE), remove the three multi pin connectors on the BCM module (top of battery, drivers side). The car will start and run on 12volt battery.
The 12v bat will not charge <1200; >4000rpm if dashboard red battery icon comes on it is not charging wait 30 seconds and the red light goes out and charging resumes. Don't drive extended distances w the red charging light on
Ima and check engine light, forever
Yes & yes
see above
. like a tired Geo Metro
see above, I've driven mine thru a Pittsburgh winter..no prob.
Don't let a bad battery screw up a good deal
http://www.insightcentral.net/forums...a-battery.html
The Following User Says Thank You to silverinsight2 For This Useful Post:
WesternStarSCR (11-06-2012)
Old 03-18-2012, 04:19 AM   #20 (permalink)
Had mine fixed by throwing new parts at it.
Mostly nuts and bolts, brake/fuel lines, rear axles, shocks, struts, springs,misc parts ...very little actually.
