Old 02-03-2013, 01:23 AM   #1 (permalink)
Can '80s 'muscle' be ecomodded?
Going to try to improve on the improbable.
1987 Oldsmobile Cutlass one of the last of RWD body on frame midsize V8 coupes.
140 odd horsepower of smogged to death goodness pushing ~3500lbs
It may be a hopeless challenge but someones got to try
The good.
Fairly sleek body design, can easily reach triple digit speeds.
The bad.
Whoever thought an electronic carbuerator was a good idea needs their head examined.
The ugly.
Can you believe GM stuck 2.14:1 final drives in these cars. 0-60 with a sun dial, but cruising with traffic and the tach staying well below 2Krpm always gives me a fuzzy feeling.
Original EPA was 17/23, revised is 15/21. Is 18/25 too far off, maybe 20/27.
Lets trim some weight off this piggy and see what she can do.
Old 02-03-2013, 02:55 AM   #2 (permalink)
Jimmy - '00 GMC Jimmy SLT
90 day: 21.18 mpg (US)
The White Gnat - '99 Suzuki Swift
Team Suzuki
90 day: 51.87 mpg (US)
Trimming weight will help most in stop-and-go city driving. Cutting aerodynamic drag will help most for highway cruising. Maxxing-out the tire inflation will help both.
Old 02-03-2013, 03:07 AM   #3 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Why bother? Sell the thing (or give it away) and get a small FE frindly car. Both cheaper and better for the environment!
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
The Following User Says Thank You to Jyden For This Useful Post:
Ryland (02-03-2013)
Old 02-03-2013, 09:41 AM   #4 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Yes......sell it! (jezzzz........)
You sell it to a boy from the hood.
He wants 'dubs'
He gets finasncing at the local rim shop and pays $3000 for 22" rims and tires. (ps europe....waste of material!!!!.........'sell it'..........)
he also gets teribble mileage.
The the car is repo'd because he cant make payments on the rims......
(should I go on...........)
you buy another car.........more waste.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following 2 Users Say Thank You to mcrews For This Useful Post:
t vago (02-03-2013), UltArc (02-04-2013)
Old 02-03-2013, 09:44 AM   #5 (permalink)
mcrews's Avatar
welcome MAD MIKE!
What about a desiel replacement at some point?
love the rear ratio!
My 66 mustang had a straight six 200 ci and a 2.89 rear ration......loved freeway driving!
ECO MODS PERFORMED:
First: ScangaugeII
Old 02-03-2013, 10:36 AM   #6 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
My opinion is swap in an obd2 engine and ecu if possible, the advanced computer controls will make a big difference.
Old 02-03-2013, 10:55 AM   #7 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Lax swap!!! For economy I vote for a junkyard 4.8 or 5.3 backed by a 6 speed and decent rear gear. Maybe 3.08 or 3.20's? Eliminate all smog stuff you can and have it tuned for economy at cruise and power when you need it.
Or is reusing the original engine eliminate all the smog stuff and add a better flowing intake/carb with better flowing exhaust. Manual trans conversion.
Old 02-03-2013, 02:23 PM   #8 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
It's simple, it's heavy and not aero dynamic... so you might be able to do better with some mods but even if you swap a diesel or even electric drive you're still using double the energy a cheap small car will use
Old 02-03-2013, 03:33 PM   #9 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
The good.
The bad.
The ugly.
First off welcome to the forum. Second don't sell it... Especially if there isn't anything wrong with it! The first thing you should do is make sure your vehicle is tuned up and happy. Air filter, plugs, wires, dizzy cap, rotor, carb adjustments, etc...
If you haven't already started doing so start keeping detailed records of your fill ups and mileage. You can calculate MPG and get a ballpark average. The first mod you should think about is to do a "driver mod". See the 100+ hypermiling tips we have here..100+ Hypermiling tips
Since you have a carb try a vacuum gauge and note what readings you get around town, on hills, cruising and on the expressway. A vacuum gauge isn't perfect but it will get you an idea of how hard the engine is working. You want to balance RPM, gear and engine load to get the best efficiency.
The physical mods should wait until you get some baseline numbers. It isn't good to start going nuts and not really know if what you did made an improvement or maybe made your fuel economy worse.
Project Avalon: E bike build
Old 02-03-2013, 04:09 PM   #10 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.26 mpg (US)
+1 to what Razor02097 said.
Your car is lighter than my truck and has less frontal area. You have a less efficient engine and (I'm guessing) an automatic transmission, but that just gives you more opportunity for improvement.
Good records + persistence is the key.
