05-16-2013, 07:49 PM
#361 (permalink)
Running the hand over the wetted surface was the acid test.
It's funny—your fingertips can find flaws you eyes can't see.
05-16-2013, 08:39 PM
#362 (permalink)
...beats walking...
...every picture I see of your car, the more my mind says "Blue Ghost"
05-18-2013, 03:54 PM
#363 (permalink)
fingertips
Yes,and also,Neanderthal may discern the difference between Cro-Magnon (spell that Daryl Hannah)
05-23-2013, 05:00 PM
#364 (permalink)
05-25-2013, 04:18 PM
#365 (permalink)
Can anyone think of a modern front wheel drive car that has double 'A' arm front suspension, that could be found used?
05-25-2013, 07:16 PM
#366 (permalink)
MPG Militia HMV-25E80+A
I found a list of fwd/awd double wishbone set ups...
- Honda Civic 1988-2000 -Tall (All I think)
- honda CRV -Tall
- Honda Accord 1994-2007 -Tall
- Honda Prelude (Same as Accord?) -Tall
- Acura Integra (Same as Civic?) -Tall
- Dodge Stratus - Tall
- Mitsubishi Eclipse 1995-1999 -Tall
- Mitsubishi Galant xxxx-1999 (Same as Eclipse?) -Tall
- Hyundai Sonata - Tall
- Lotus Elan M100 - Short
- Saab 900 - Short Possibly Perfect choice
- Infinity G20 - Short but has a crazy tall upper control arm
- Pontiac Solstice - Short (RWD Rear Knuckle)
- Saturn Sky - Short (RWD Rear Knuckle)
- Chevy/GMC S10/S15 Blazer/Jimmy 4x4 - Shortish
- Dodge Dakota/Durango 4x4 - Shortish
The tall/short at the end is just a relative assessment by the poster of their upper arm height.
The post is JY FWD/AWD Double Wishbone Source: Grassroots Motorsports forum: Grassroots Motorsports Magazine
The Following User Says Thank You to JethroBodine For This Useful Post:
05-25-2013, 11:40 PM
#367 (permalink)
Saab 900, huh? Does it have torque steer? I do need it to be compact.
Some may have tower struts? I like the pivoting spring - that means that the springs could be reoriented to bear against each other in the middle, so the stress on the chassis would be less.
I also need to tie the steering into a linkage to push the wheel skirts out; and I need to place the steering column, too. This is going to get really interesting...
Thanks for the list!
05-26-2013, 01:50 AM
#368 (permalink)
Why not make your own? you're already building the whole car. Better off to make it exactly how you want.
LocostUSA.com • Index page
That site should be of assistance provided you go the route of custom fabrication.
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
05-26-2013, 04:55 AM
#369 (permalink)
Double-A arms are less prone to torque steer than McPherson struts
05-26-2013, 01:49 PM
#370 (permalink)
Making my own would be a *lot* more expensive. I want to spend less and I want to get to a point when I can can actually drive it, and test it. Compact double 'A' arms may need some mods, but still would be a lot easier that fully custom suspension.
I drove some early Saab 900's and they had a lot of torque steer; especially the turbos... I can deal with it, but I know that some front wheel drive setups are quite neutral.
The rear suspension, though will likely have to be custom. Though I should look at the Honda Prelude with the active rear "steering" as that would have less turning scrub, I think?
