Old 09-17-2011, 10:44 PM   #1 (permalink)
Joe1234's Avatar
Question Civic VX: Headers vs stock exhaust
Bought a partially molested/riced out Civic VX. One of several things I have to undo are the headers that were put on it. How bad is my fuel economy going to suffer with header assuming all other factors are the same?
Also, where can I buy the stock manifold and CAT?
Old 09-17-2011, 11:31 PM   #2 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Before you know for sure what your actual FE numbers are with the exhaust manifold and header, I wonder if you want to invest in stock items. The race mods might work well with proper driving, maybe better than stock if they are good items. A tuned exhaust manifold and muffler has the support of some on this forum as a good FE move. Any chance you could run them for a while, track FE carefully, and get a baseline on the car in current form? Or have you done that already?
Old 09-17-2011, 11:58 PM   #3 (permalink)
Joe1234's Avatar
The only "performance" mods it has are K&N intake and headers. The rest of the mods were really tacky exterior mods. How do you tune the custom exhaust? Is there an adjustment somewhere? It also has one of those retarded fart pipe mufflers. The O2 sensor port is on cylinder 1 exhaust instead of where they all come together on the OEM manifold.
Old 09-17-2011, 11:59 PM   #4 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
There are a number of on line calculators that will tell you what the ideal size is for exhaust and headers so you can get an idea how over sized they are.
I would place an ad on craigslist and contact people who are selling VX parts asking if they have these stock parts, you could get them for scrap value.
Old 09-18-2011, 12:36 AM   #5 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
A 'tuned' exhaust manifold is made that way. you can't 'tune' it.
With thAT said, you need to look at or tell us, the od of the pipe that is leaveing the maifold. If it is too big, your screwed.
There was a thread on here last month on this exact issue..
Basicly what you probably have is a pos, noise making ricer setup.
I doubt that any real intelgent thought went into whAat was bolted on.
"we' have said this before, and 'others' have belittled it(they are wrong) but there is an optimal size in od exhaust pipe for every size of engine. If you are not at that size then you are not going to optimize the engine's ability. PERIOD.
And if your here, you are not going to be running your engine at 4000 rpms more than 5% of the time. Or 3000rpm.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 09-18-2011, 12:41 AM   #6 (permalink)
mcrews's Avatar
here:
How To Calculate Muffler Size and Exhaust Pipe Diameter | Exhaust Videos
ECO MODS PERFORMED:
First: ScangaugeII
Old 09-18-2011, 12:56 AM   #7 (permalink)
Joe1234's Avatar
I thought the problem was back pressure. The stock setup has the correct back pressure while aftermarket headers with no cat will not have enough back pressure.
Old 09-18-2011, 01:01 AM   #8 (permalink)
mcrews's Avatar
Exhaust Size Calculator
this one is VERY simple.
NOTE: MAX horsepower......something none of us should see more than one on a car.
ECO MODS PERFORMED:
First: ScangaugeII
Old 09-18-2011, 01:03 AM   #9 (permalink)
mcrews's Avatar
your right.
POTENTIALLY, the pipe could be small enough to allow for enough pb.......but until YOU measure it......why are we having this discussion?
ECO MODS PERFORMED:
First: ScangaugeII
Old 09-18-2011, 01:18 AM   #10 (permalink)
Joe1234's Avatar
I'm guessing the 1.5" pipe diameter the calculator is referring to is the final exhaust not the pipe diameter coming out of each exhaust port. lets say, for example, the pipe diameter I have is too large, then what?
