09-19-2012, 10:38 PM
Honda modder
crx-hf front aero clip
Made of foam, saves about 3mpg at hwy speed.
The Following 2 Users Say Thank You to darrylrobida For This Useful Post:
09-20-2012, 08:01 AM
Super Lurker!
Rusty - '88 Chevrolet S10 base 90 day: 23.72 mpg (US) Doc - '08 Honda Civic EX-L 90 day: 29.6 mpg (US)
Nice! Looks really good.
The Following User Says Thank You to Slow_s10 For This Useful Post:
09-20-2012, 09:12 AM
Very interesting. Care to share how you made it and attached it?
The Following User Says Thank You to Daox For This Useful Post:
09-20-2012, 10:01 AM
Honda modder
Yes
Made of 1.5" 4'x8' sheet styrofoam from Home Depot at $17 per sheet.
Original Gorilla glue works great on this foam. Imbedded in the clip
are spruce wood for all the attachemnt points. It is fully bolt on.
Finally, it is covered with redneck fiberglass (latex paint over
cheesecloth). I am very willing to share all my mods in full detail.
Thanks for your interest. Darryl
09-20-2012, 12:01 PM
That looks awesome, I really like it. Do you have any other pictures, from the side, and maybe the inside or pictures during the build?
That 3 mpg, how was that determined if you don't mind me asking? Any idea of a % improvement? I'm not trying to be too critical, just curious since 3 mpg gain is a huge difference between a normally 20 mpg car and a 50 mpg one. I have been considering something similar to this since seeing the Aerocivic and WeatherSpotter's threads.
The Following User Says Thank You to 2000neon For This Useful Post:
09-20-2012, 02:00 PM
Honda modder
3mpg is an estimate. That figure is for high speed freeway driveing. As to how I measure MPG. I've tried computers and Mpguino and have come to a conclusion.
I will use a graduated cylinder for gas volume and a calibrated rear trailing bicycle wheel.
Also, why doesn't anybody blog about using a manometer to measure vacuum behind the vehicle?
09-20-2012, 05:32 PM
Honda modder
More pictures, (2) yes, for you.
Yes, (2) more photos for you. Damage is from an unusually high curb.
The Following User Says Thank You to darrylrobida For This Useful Post:
09-20-2012, 06:01 PM
Thanks a lot, that looks really cool! I like it!
Is it basically hollow? Looking closer I love the cutout for the hood release as well.
09-21-2012, 07:58 AM
#9 (permalink)
This looks great! Nice work!!!!!
The Following User Says Thank You to turbovr41991 For This Useful Post:
09-21-2012, 08:51 AM
#10 (permalink)
Honda modder
Yes, It is hollow. My secret for rapid fabrication is to limit the amount of cutting
and shaping of the foam. Notice the top surface of the clip is flat (totally un shaped).
Then, for the front wrap around, i relief cut the foam from the back so as to allow it to
bend to the curve that you see in the photo. Note the relief knerf cuts are later\
backfilled with expansive gorilla glue to restore the full strength of the foam.
