Old 06-24-2013, 05:55 AM   #11 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
I have deleted both A/C and P/S and I'm not missing that at all For sure engine is spinning much easier at idle so if you're coasting with engine on you'll gain some FE for sure.
I can't provide any numbers though because I haven't done any A-B-A tests.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 06-24-2013, 08:48 AM   #12 (permalink)
Camry - '99 Toyota Camry
90 day: 39.84 mpg (US)
You're right I will probably just leave it off lol
Old 06-24-2013, 08:51 AM   #13 (permalink)
Yeah I do quite a bit of neutral coasting
Old 06-24-2013, 04:46 PM   #14 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Since my power steering belt broke last summer I have noticed no real difference in mileage.
Old 07-02-2013, 05:59 PM   #15 (permalink)
I have taken the belt off today we shall see what gain I see. I took it for a test drive at slow speeds it takes more effort to turn but not terrible at speed its fine. I did notice it coasted longer without the belt on.
Old 07-03-2013, 12:59 AM   #16 (permalink)
I recently did a test where I spun the P/S pump up to different speeds using a power drill, optical tachometer and kill-a-watt meter.
The results were at 850 RPMs the P/S pump took almost no power to spin at that speed only detected about a 150 watt draw.
The posibility of gaining any MPG improvement form a P/S delete were looking to be slim to none.
But when I did the test at a more normal cruising speed of 2000RPMs the P/S power consumption jumped to about 500 watts.
For a small car that turns higher RPMs on the highway that should make at least a 1MPG difference.
With my suburban a 500 watt accessory reduction should make at least a half MPG difference.
sully06 (07-03-2013)
Old 07-03-2013, 02:07 AM   #17 (permalink)
Yeah I don't expect to see high gains but I'm looking at the big picture my goal is to get to 40 mpg. One less accessory will increase coasting as well
Old 07-03-2013, 09:50 AM   #18 (permalink)
justme1969's Avatar
Blew the hose 2 years back. I couldnt find one so did a simple bypass to keep neutral hydraulics action and fluid inside the rack n pinion.
I did see a 1/2 mpg increase but project snow balled at this point and it would have required 3-4 tanks test to give you solid returns answer and that never happened.
The new more amperage toyota alternator and Largest battery I could fit were next added 2 weeks later.
This was a 1+ mpg mod also because Darkened morning drive kept running Alternator on constant .
Small Batteries are lighter but wont run headlamps for long till alternator starts constant on off cycles. "Good Mod" for night drivers.
Also larger pulley reduces voltage peak mine went from nearly 14.4vdc to 13.2under driving it.
I never looked back and cant say exactly how much had changed where, as said I went into modding it full force and fast.
The Following User Says Thank You to justme1969 For This Useful Post:
Old 07-03-2013, 12:03 PM   #19 (permalink)
Cinco The Miata - '90 Mazda Miata
Team Mazda
Sports Cars
90 day: 36.13 mpg (US)
Oscar Wilde - '02 Honda Metropolitan
Motorcycle
90 day: 94.9 mpg (US)
I deleted my power steering and air conditioning and felt like it made it made a noticeable improvement in my mileage.
Old 07-05-2013, 02:38 AM   #20 (permalink)
Exceptional Member
YukonCornelius's Avatar
Crapolier - '98 Chevrolet Cavalier base
90 day: 34.81 mpg (US)
05 CTS-V - '05 cadillac cts-v
90 day: 33.01 mpg (US)
95 Accord - '95 Honda Accord
90 day: 38.06 mpg (US)
11 CTS-V - '11 Cadillac CTS-V
I thought about doing this in my accord but in a fast acting swerve scenario I would regret that mod. I would hate to not be able to control my car properly to save a little gas.
Don't know why it says 00, it's a 95
374,000 miles and tired.
