Old 09-18-2015, 01:32 AM   #11 (permalink)
aerodynamicist
Did your spell-checker flag it? Mine does, but yes it is.
Exactly reproducing the M-B would be very difficult, but working at the level of race-ready fit and finish isn't at all unreasonable. It isn't all corplast and duct tape here. To pick an example, Bondo's Aerolid
http://ecomodder.com/blog/aerocaps-for-pick-up-trucks/
It's articulated and has a high level of finish.
For materials I would pick PolyMetal and silver solder, and the articulation would be manual using 4 or 6 parking brake cables on a hand lever.
jedi_sol (09-18-2015)
Old 09-18-2015, 02:56 AM   #12 (permalink)
Send a message via MSN to markweatherill
Originally Posted by Grant-53 View Post
an air supply.
I just imagined a package mounted at the rear of a car, like a deflated and rolled up air mattress in construction. It's attached to the tailpipe, with its own ventilation outlet(s) so the gases will pass through it.
You start the vehicle, it begins to inflate into shape and stays up while the engine is running. Now, when you switch off the engine, it deflates and by some clever elastic cord arrangement, more or less folds or rolls itself back up.
It must have valves to relieve excess internal pressure, it must drain any condensation, and must be proof against corrosion.
Old 09-18-2015, 03:02 AM   #13 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Given the talents shown on this forum I have no doubt this could be done. This is an intermediate level project that a competent technician or community college class could do.
I have no doubt ecomodder can pull this off either. Much like MB r&d, it'll have to be a group effort. I'm sure we all can name at least 5 ecomodders that can pull this off, but the problem will be getting them in the same room
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 09-18-2015, 03:45 AM   #14 (permalink)
The other problem is doing it in a "legal" manner. The merc concept wouldn't be legal to produce in the UK. For one the rear lights cannot be seen from the side of the vehicle, it's possible, but in the UK if you cover the tail lights or the number plate the police will be on your case in an instant.
The easiest way I can think is to make a diffuser on runners, with a little motor on a worm gear and two limit switches, fully open and fully closed.
You'd have a step in the floor, but it'd be better.
The material can be anything really. Think of a drawer.
It can reside inside the rear bumper above the undertray using a slot...
The sides I cannot begin to think of a way to do, due to blocking the lights from certain directions ( safety is number one!)
A lengthening spoiler would be very car specific also really difficult, but less so than the sides
Old 09-18-2015, 04:01 AM   #15 (permalink)
90 day: 55.9 mpg (US)
The tail lights can be mounted on the end section.
Those would be visible from the sides too if that section is a bit longer that the rest.
Could do with extra indicators on the first section just to be sure.
If the sides of the OEM tail lights remain visible I'd leave those connected.
Old 09-18-2015, 08:08 AM   #16 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
What if you had a central section (lights and plate mounted on it) that would be tapered. THIS would extend straight back inside the outer shell that would be hinged to be somewhat flexible. The center section would ride on rails.
I'll try to draw a photo to help illustrate what I'm talking about.
Ok, that didn't take long. This is a TOP DOWN VIEW.
Retracted for parking and maneuverability:
Extended 12":
Old 09-19-2015, 01:33 PM   #17 (permalink)
inflates
Here is the original concept from the 1930s
The envelopes ARE subject to aeroelastic forces.I had to include a rigid lower brace to combat Karman Vortex Street oscillations
A dedicated rigid lower structure stiffens the envelope and also fixes the diffuser angle
The Following 4 Users Say Thank You to aerohead For This Useful Post:
BamZipPow (09-19-2015), gone-ot (09-19-2015), jedi_sol (09-19-2015), UFO (09-20-2015)
Old 09-20-2015, 08:23 AM   #18 (permalink)
I just realized my idea probably wouldn't do anything because the AREA of the rear edge isn't smaller at all. Sure it's extended a little bit, but it isn't tapered any further.
Old 09-20-2015, 08:26 AM   #19 (permalink)
Aerohead, while great for the aerodynamics, how would you work the issue of tail lights and legal license plate location?
The Following User Says Thank You to whatmaycome14 For This Useful Post:
aerohead (09-21-2015)
Old 09-20-2015, 01:21 PM   #20 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Leds across the flat@rear. Appears to be ~2" tall. Thats more than plentiful for a series of 3/8"leds
Move plate above the transformer section. Withi ts associated light. Geting an extra plate dusnt seem likely. (1on display 1 folded up)
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
