Old 11-17-2007, 12:14 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
DIY: Push Button Start
Everyone envies the person with the push button start. Perhaps it's that cool cat with the S2000 or the fuel miser with the hybrid, but they envy is still there. With this write up I intend to show everyone how easy it is to add this to your own vehicle. This was done using CRX wiring, but with a simple check of wiring this can be duplicated for almost any vehicle. If you do this don't forget to send me a picture of you setup!
Purpose: There's the bling factor of having a push button start (especially if you use the s2000 "engine start" button, the anti-theft factor if you wish to hide the button, and the convenience factor of having the button near the shifter if you are using it during engine off coasting.
Time: 1 hour
Tools:
- Soldering Iron
- Wire Stripper/Crimper
- Screw Driver
Supplies:
- 1 SPDT (Single Pole Double Throw) Relay - 3.99 at my parts store
- Some female quick connect ends - 2.99 at the parts store
- Wire
- Solder
- The button!
Check out this schematic and look at your SPDT relay, pretty simple. Figure out which wires are which and wire the stuff up. I labeled this with the colors that are actually used in my CRX. This write up is applicable to almost any car, but you'll need to figure out which wires are which if you want to do this to another car. Pretty simple. Most people use the S2000 start button, but you can use any button that is normally open and only connects when pressed.
And here's a picture of the S2000 button, just for reference:
Wire the stuff in there not too prettily just to make sure it works. Here's mine half done:
Another shot with indications and all that on it.
Get your button and figure out how to mount it. I am going the way of small button skirted by washer and then mounted in my cigarette lighter hole. Here's the washer pre mounting and painting. I hot glued and burnt myself quite a bit, be careful.
I put this little cone over the button to paint the washer.
Painted shots, looks decent to me:
Wrap your crippled, burning hand in wet stuff:
Mount up the button itself into the center console part.
Finished the install with the new button, check it out:
Here's a final shot having actually put the interior back in my car:
I'm very happy with it, piece of cake, as well.
Old 12-12-2007, 01:03 PM   #2 (permalink)
so how do you go around your steering lock with no key?
Old 12-12-2007, 01:07 PM   #3 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
^^ You still need the key -- but the button makes restarting a button push
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 12-12-2007, 05:47 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
True enough! I mainly did it for the bling factor, even though I didn't end up shelling out for a prius/s2000 pushbutton.
Old 11-13-2008, 01:05 PM   #5 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Must subscribe, I keep losing this thread and forgetting about it.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 11-13-2008, 02:05 PM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
It's not that hard to just do and be done with,
Old 11-13-2008, 02:43 PM   #7 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
SVO, if you want extra ecomodder bling factor, put a normally closed push button in series with your ignition line. Push that and your car shuts off, push the other one and it start up again.
Old 06-07-2009, 10:16 PM   #8 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
good thread
is it possible to repost the pics again?
Past Present Future?
Old 06-20-2009, 06:19 PM   #9 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
So how does the button change the actual operation of starting the engine? Is it on-off or do you still use the key for that?
This is new to me and I'm not sure I understand how you wired it up. Is it just for activating the starter?
-Allch Chcar
Old 06-20-2009, 07:10 PM   #10 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Pontiac Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
You turn the key to the "on" position then push the button instead of turning the key one notch farther to the "start" position.
1996 Pontiac Bonneville SE 3.8L V6
