Old 07-02-2014, 10:08 AM   #1 (permalink)
Need help instaling a Kill Switch
Hello
Can anyone please help me installing a Kill Switch on my Fiat Bravo 1.4 T-jet
I have the engine service manual, just need someone to point me to the correct cables so I can do something like this mod:
http://ecomodder.com/forum/showthrea...sti-26749.html
I like Sedi_Sol idea because seems very simple and clean
The ECU pin-outs is annexed is here for your consideration:
https://drive.google.com/file/d/0BwP...it?usp=sharing
Thanks you and happy driving
The Following User Says Thank You to andrenoites For This Useful Post:
jedi_sol (07-02-2014)
Old 07-02-2014, 10:49 AM   #2 (permalink)
Since the manual have many useful information about how the ECU uses the sensors I decided to post the complete document:
Cheers
Old 07-02-2014, 11:52 AM   #3 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
I wired a kill switch into my car using the crank sensors wire that runs into the ECU.
It does throw a *check engine light* on the VW but it will not on all cars (check on a Fiat Bravo forum for the preferred method)
2 wires run from the sensor under the hood to the ecu ,your wiring diagram will give you the color code to find the wires in the loom , expose the loom sheathing just ahead of the ECU itself to search for and splice into and solder in some wire and a on/off switch, mounted somewhere in a inconspicuous yet convenient place to use.
But
You could also wire in a fuel injector kill switch , which would shut the motor down as well.
Or wire into the ignition , which may work the best way to avoid a check engine light.
With the crank sensor kill switch I did to my car it causes a check engine light Plus I need to cycle the ignition one turn back then forward( a issue caused by VW's security ignition system)
If I was to do it again I would use a ignition kills switch in hopes the *VW* would not need its key cycled to start again on the next jump start.
I suggest you check the Fiat Bravo forums for the best method.
Save gas
The Following User Says Thank You to ecomodded For This Useful Post:
Old 07-02-2014, 02:35 PM   #4 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Different cars react differently to kill switching. My old honda del sol, i kill switched the ignition ground.
However, on the Sti...the ignition ground also merges with other sensors and components, therefore, killing the ignition made my dash board light up like a christmas tree. After some experimentation, i resorted to the crankshaft position sensor kill switch.
You'll just have to experiment! But i'll take a look at your service manual to see if i can find any possible solutions.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 07-02-2014, 05:24 PM   #5 (permalink)
Thank's for the help guys
I just want to make sure I don't kill my car with a wrong wire combination
I do a lot of EOC using the ignition key, the kill switch will be a nice upgrade
Old 07-02-2014, 07:12 PM   #6 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
it looks like you have a training manual...its kind of vague.
from all i can tell, you may want to put a kill switch on #11 ignition wires or #13 fuel injectors or #6 fuel pump. however, i strongly suggest AGAINST from tapping into any wires that go into the ECU.
Fuel pump #6 will not yield the best results because it still takes 3-5 seconds before it completely shuts off, therefore, it spits unused fuel into the combustion chamber.
However, if you're able to find the SERVICE MANUAL...it would be a lot more helpful in looking for alternatives on where to install your kill switch.
Old 07-03-2014, 05:54 PM   #7 (permalink)
I got this from the service manual, does it help?
https://drive.google.com/file/d/0B6w...it?usp=sharing
Tks
Old 07-04-2014, 08:05 PM   #8 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
didnt see anything helpful in that one either.
Do you have the wiring diagram for the engine bay from the service manual?
Old 07-05-2014, 08:47 AM   #9 (permalink)
Yes I do:
Old 07-05-2014, 02:17 PM   #10 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
Can you post up the entire service manual on your google drive? I need to see the descriptions of each of the wiring circuits....similar to the diagrams I put in my thread.
