07-17-2017, 07:09 PM
#51 (permalink)
Karmann Eclectric
Air box radiator mod for WAI
I didn't realize until recently that my 2000 Honda Odyssey actually has a tiny radiator in the air filter box that only gets coolant flow in very cold conditions. Does anyone know if that feature was on many other models, and has it been modded to function as a WAI for not just warmup, but also for reduced pumping losses on the highway? On this thread I haven't seen any intake temperature goals under different conditions. I'd rather not just "go hotter 'till she pings".
2012 Mitsubishi i-MiEV, 112 MPGe
2000 Honda Odyssey
1987 F250 Diesel, 6.9L IDI, goes on anything greasy
1983 Grumman Kurbwatt, 170 kW "Gone Postal" twin
1983 Mazda RX-7 electric, 48 kW car show cruiser
1971 VW Karmann Ghia electric, 300 kW tire-smoker
1965 VW Karmann Ghia cabriolet, 1600cc
Have driven over 100,000 all-electric miles!
The Following User Says Thank You to jray3 For This Useful Post:
07-17-2017, 08:06 PM
#52 (permalink)
MPGuino Supporter
iNXS - '10 Opel Zafira 111 Anniversary Suzi - '02 Suzuki Swift GL
I also did not know about this feature, and would also like very much to know if any other models had this feature installed from the factory.
I don't worry so much about that. Even if the intake air is heated to near the boiling point of water, the fuel spray from the injectors should cool the air to a few degrees above ambient. This happens because the fuel cools off the intake air as it vaporizes and sucks in latent heat of vaporization from the heated air. I already heat the air in my Magnum to about 40 or 50 F above ambient with a old Ford Probe heater core.
The Following User Says Thank You to t vago For This Useful Post:
07-28-2017, 10:58 AM
#53 (permalink)
Do we have any data on what the ideal intake temperature should be?
It would be fairly easy to create a switched input for the wai.
07-31-2017, 01:44 AM
#54 (permalink)
not really
warmer air is better for combustion but less 02 as warm air is less dense ;
colder air is denser , more air = more 02 = more power available at WOT
mr computer
already has control of fuel and timing so
mr computer
will match air temp to a calculated value of timing and fuel volume which will be corrected in a feedback loop
from inputs from the AFR or 02 sensor in the exhaust
you
can not change anything
mr computer has control
so
heat the air as much as you feel will help ,
watch knock retard values in your scan tool and when they start to increase
beyond the baseline value
stop increasing air temp
of course you need a baseline scan data test graphed or logged of knock retard
at various loads
and ambient temperatures
before you begin your modification
07-31-2017, 03:41 PM
#55 (permalink)
Thank you for the feedback.
I am fairly familiar with the workings of the ecu.
I was planning on reading the iat from the canbus and establishing a pid loop with a servo that moves a flap between 2 intakes, one that is cold and the other ducted to the exhaust manifold.
It should be fairly straightforward creating the control loop (wish the obd2 protocol would be faster) and an analog sensor in the manifold could be preferrable.
Would the input temp be dependent on rpm or load? Obviously you would want cooler air if accelerator is %100 in case of emergency.
08-01-2017, 06:39 PM
#56 (permalink)
Karmann Eclectric
Good, thx. Running 1200 highway miles this past weekend with the Odyssey upper grill blocked and over 90 degrees ambient temps, I usually saw 120-124 degree intake air temp on my scangauge (and coolant temps of 190 to 217). That plus a lot of time spent at altitude of over 2000 feet must've really thinned out the intake air, but no problems. The van delivered 24 mpg steady at speeds of 75-80 mph for 300+ mile stretches. Not bad for an engine with 226k on the clock!
2000 Honda Odyssey
08-01-2017, 11:01 PM
#57 (permalink)
MPGuino Supporter
No, not bad at all, sez I. The 2000 Odyssey was rated at 23 MPG on the highway. That you got 24 under sustained high speed highway driving says a lot.
08-26-2017, 07:35 PM
#58 (permalink)
EcoModding flying lizard
The more air you are sucking in, the cooler the air will be. When I am coasting with the engine idling, intake temps go 40+ degrees F above ambient temperature. Driving around with steady throttle I think was around 10-20 degrees F above ambient.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
Originally Posted by MetroMPG
You can lead a fashion-conscious horse to unusual-looking water...
08-26-2017, 08:20 PM
#59 (permalink)
I had in mind some sort of electronics wizardry to get the air from the hottest part of the exhaust manifold and keep it at a fixed temperature no matter the airflow. ( but i sold that car, and now have a turbo car, so i am not sure if this is such a good idea).
What i should have asked is, should the input temperature be dependent on rpm and load. Or is a fixed X F or C best or is there a more complex algorithm.
08-27-2017, 05:33 AM
#60 (permalink)
MPGuino Supporter
I can get a good 60 degree F difference between ambient and intake air temperature in the winter time. In the summer, the difference drops to about 40 F or 30 F.
