Old 01-18-2015, 12:17 PM   #41 (permalink)
Silver Magnum - '03 Dodge Ram 1500 Laramie
90 day: 11.43 mpg (US)
Originally Posted by razordave View Post
Got one for you. Turbo 1.6 honda engine on a trailer. Just buy a civic and use the trans, engine and ecu to make a pusher trailer easiest to use an automatic trans but I'm sure it wouldn't last long pushing a monstrousity of a truck.
This could work, what about a smaller/older engine with less output? It only needs to push my truck at 45 max.
Old 01-18-2015, 03:51 PM   #42 (permalink)
90 day: 30.54 mpg (US)
Originally Posted by Striker2237 View Post
Yes but that engine is weak, I'm not looking for a weaker engine
Except Kubotas.
Old 01-18-2015, 04:07 PM   #43 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by jakobnev View Post
I've had similar ideas. One was for a muscle car with a little 3-cyl cubota in the trunk with it's own transmission to the rear diff.
The other was for a Ford festiva with a 125hp 1.0 ecoboost at both ends of the car. And a neutral lever next to the gear shifter to lock one of the transaxles in neutral.
Plenty of room in the trunk on this one !
Old 01-18-2015, 06:54 PM   #44 (permalink)
Except Kubotas.
well what i meant is that hemi would take the place of my engine, and 345hp is not anywhere close to 620
Old 01-23-2015, 11:39 PM   #45 (permalink)
iowahawk: The Real Acme
This sounds like exactly what you are looking for.
Striker2237 (01-24-2015)
Old 01-24-2015, 12:22 AM   #46 (permalink)
Mmm one thousand horsepower on your rear axle. Ill take two for my new awd crx plans! Sorry guys, but to hell with mpgs when im sure I could do the quarter in 2.8 seconds in my now 1500 pound 4wd crx. I knew there was a reason I kept calling them the rocket cars..
Great read btw, that guy can write!
The Following User Says Thank You to razordave For This Useful Post:
freebeard (01-24-2015)
Old 01-24-2015, 03:18 AM   #47 (permalink)
Okay so I did some digging and came up with some numbers, for my truck to accelerate to 45mph it requires about 315 LbFt TQ at 1900 rpm or about 170 hp, to maintain this speed about 280 LbFt TQ at 1370 rpm or about 145 hp is needed. This would mean that in order to even maintain my 45mph speed I would essentially need my friend's 1.5L civic engine at more than its max power to keep my truck moving......or did I get this totally wrong? (I used a stock 5.9 magnum dyno chart plus memory of old rpms and speed readouts to try and find out how much power is needed for a given speed.....thats not wrong is it?)
Old 01-24-2015, 03:31 AM   #48 (permalink)
Totally off sir. Im not sure how to figure t hat out but a 360 is definitely not the smallest engine that could possibly move your truck. They used to put a 3.9 i believe in the three quarter tons and was more than ample.
Old 01-24-2015, 03:33 AM   #49 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
An average car cruises on about 7hp at moderate speeds. I could see a truck needing maybe 50hp max at cruise.
To work this out you need your hp for given speed/rpm X load. If your truck cruises at 30% load then that's about 50hp based on your figures.
Old 01-24-2015, 03:58 AM   #50 (permalink)
Crap.....okay I guess i'm not factoring gearing into this.....I'll be back in the morning to try this again.....
