Old 10-30-2010, 07:53 PM   #81 (permalink)
Gen II Prianista
Rokeby's Avatar
I'd like to recognize, even applaud, all the members who have taken part in
this discussion. You have provided information that each of us can pursue in
trying to understand the legacy that we will leave to future generations.
All too often, discussions like this tailspin into rancor, and ugliness.
Here it hasn't ... well, not yet at any rate, and I don't expect it will.
In addition to being Ecomodders, I think you also have a valid claim to be
"Equmodders"... "Equ" being short for equable:
Equable \E"qua*ble\ (?; 277), a. [L. aequabilis, fr. aequare to make level or
equal, fr. aequus even, equal.]
1. Equal and uniform; continuing the same at different times; -- said of
motion, and the like; uniform in surface; smooth; as, an equable plain or
globe. [1913 Webster]
2. Uniform in action or intensity; not variable or changing; -- said of the
feelings or temper. [1913 Webster]
Well done, and thank you.
The Following User Says Thank You to Rokeby For This Useful Post:
NeilBlanchard (10-30-2010)
Old 10-30-2010, 08:15 PM   #82 (permalink)
Glacier National Park in 1850 had 150 glaciers.
Today, in Glacier National Park there are ... 25 glaciers.
What will we call Glacier National Park when all the glaciers melt?
Media Player | Here & Now: Climate Change Changes Fall Colors
Carbon dioxide controls Earth's temperature
Notably, the team identified non-condensing greenhouse gases -- such as carbon dioxide, methane, nitrous oxide, ozone, and chlorofluorocarbons -- as providing the core support for the terrestrial greenhouse effect.
Without non-condensing greenhouse gases, water vapor and clouds would be unable to provide the feedback mechanisms that amplify the greenhouse effect. The study's results will be published Friday, Oct. 15 in Science.
Edit 1: Another amplifying/feedback loop: when there is more open water in the Arctic Ocean, it absorbs more heat from the sun, because the albedo of the dark water is much lower than the albedo of snow and ice; which reflects the light and the heat more.
Edit 2: Ten hottest years on record:
2005
1998
2002
2003
2004
2001
1997
1990
1995
1999
Edit 3:
The tropics have expanded 2 degrees latitude north and south since 1980. This added 8.5 million square miles of tropical climate. This has pushed the subtropics toward the poles, moving the weather patterns with them.
Old 10-30-2010, 08:20 PM   #83 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Originally Posted by Arragonis View Post
Hi,
I know this is insignificant but...
I'm 'retiring' from this debate at this point. Not because I don't believe in my position (which is of the "I don't know" strand of skepticism - aka the largest strand) but rather because I don't want to continue in this particular argument in this forum. I don't believe it adds any value to EM.
I believe most people come to, and contribute to, EM for the best reasons to themselves, mainly those are -
- AGW, I want to reduce my carbon footprint
- Political - I want to rely less of 'foreign oil' (depends where you live)
- Financial - I want to spend less
- Science - I want to be more efficient / waste less.
I have respect for all of those even if they are not my own.
I am 'retiring' because I just don't want to get into an argument over this and 'fall out' with lots of (internet) people I have come to respect, like Neil - I do read his posts and his threads a lot, I have even been known to visit his blog.
I don't agree with him over AGW but I will still watch his threads and his posts here with interest, especially the CarBEN project.
In the interests of balance with the original post I would recommend some other books like AW Mountford's "The Hockey Stick Illusion" or indeed Ian Plimer's "Heaven and Earth" for a balanced view alongside "Eaarth" (which I have only started reading). Yes I read both sides.
So with that, peace and Cheers everyone.
A.
Good points.
I agree that we should not get to the point where we are clashing with each other. I respect people on both sides and think that they have good advice for ecomodding, so lets keep the topic more to that nature.
Have fun modding your cars
Old 10-30-2010, 11:30 PM   #84 (permalink)
http://nsidc.org/arcticseaicenews/
Notice that not only in the extent of the ice much smaller, the minimum is happening later in September, the average age of the ice is much younger, and the maximum is lower than the mean for 1979-2000.
Old 10-31-2010, 09:24 AM   #85 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
That's why this period is called an interglacial.
The ice left over from the previous ice age will melt.
And the longer this period lasts, the more ice will melt.
That's the normal scheme of things.
Driving through the valleys in the Alps, chances are good you'll be driving through valleys carved by glaciers that have long been gone.
Same experience can be had in the Rockies.
Cruising the Norwegian fjörds, you're sailing where glaciers once shaped the now stunning landscape.
Nobody's complaining that these glaciers have long vanished, or has started a global scare because of it.
It all boils down to what you pick as your reference period - wether for artic ice or glaciers.
What's the reference period against which to judge todays evolutions.
Picking the reference period, clearly determines how bad things are. Or rather appear to be.
The Holocene graph on Wikipedia labels the period 4 to 8 K years ago as a climate optimum.
Well, we're solidly within the proxied temps from that period.
Look at the spikes you can see there.
Some of them are pretty impressive and point to quick changes in temps recorded in these proxies.
It also shows the reversal in the lightblue and red proxies, with the red proxy spiking again - like it did 10, 11 K years ago.
Climate changes, and apparently it changes quite drastical depending on time and place.
What do we call squares when they are anything but square ?
We still call them squares.
As for the TED presentation, I called it quits when the bloke started about indisputable truth. Once the truth-word is out, once the indisputable is claimed by either side, a debate is no longer possible and you end up in religious-like thinking.
It should be noted that these truth-words in what previously was a climate debate have almost invariably come from the believers' side. Wether it's this TED presentation, An Inconvenient Truth, or the title on Sir Attenboroughs contribution.
That's where the believers in the scientific world have crossed over to the religious/artistic world, and have started screaming "Panic" and have started working on emotions. Have started preaching their beliefs.
And we should note that it hasn't been too pretty or ethical, with instances of believers trying to keep sceptic scientists from publishing or gaining a forum in the controlled media.
If one can't prove his point, these would be the very tactics to push one's beliefs. It's how it was done in the past.
A sceptic isn't an opponent.
It's someone you need to convince with hard facts, not with claims that it is so-and-so. Sceptics won't be won over by the sort of scheming and plotting unearthed by the Climategate scandal either.
If one's really telling the truth, these ploys are quite unnecessary.
Clearly all these effects somehow also create the conditions that lead to the climate cooling down again.
The dust in the Vostok graph could well be that trigger mechanism
Yes. So what ?
We've only been recording for a ridiculously short period of time.
And no-one's debating that the climate is indeed changing.
It has done so forever. It did so before humans even existed.
Climate change doesn't need us to make it happen - and far less to prevent it.
What really frightens me is scientists developing methods to cool down the atmosphere by doing things like emitting sulphur into it, and getting a worldwide media forum to propose these techniques.
They're proposing to actively alter the climate because they see a change they do not fully understand and can hardly explain.
If we were to accept the theory - 'cause it isn't more than a theory - that CO2 drives climate change, the greenhouse effect and all that, then why aren't we seeing unprecedented temperatures with unprecedented levels of CO2 ?
Compared to the coldest periods in the ice ages, temps were 8 to 10° lower, and CO2 levels were 100ppm lower than the claimed "optimum" of 280ppm.
We're now at 100ppm more CO2 than that, so where's the 8 to 10° increase in temperature when compared to the optimum
We're not seeing anywhere near that increase in T.
What are we seeing ?
Temperature peaks that are still lower than proxied temperature peaks 7 and 8 thousand years ago.
And those in turn are still lower than the proxied temperature peaks of the previous interglacials.
It wouldn't take very long for that giant microwave oven called Sun to heat up Earth.
Our total energy consumption is merely 1 thousand of the Sun's energy input on earth.
Yet such an 8 to 10° drop is easily achieved by being rotated away from the sun for a mere 8 or 12 hours, and in a couple of hours, the temperature is restored by turning into the sunlight again.
It just gives an idea of how massive the Sun's input on our climate is.
Using all the human-burned fossil energy, you still wouldn't be able to replicate this daily cooling / heating cyclus. We use a lot of that energy just to buffer the temperature in our small micro-climate enclosures called buildings.
Do we need fuel conservation, and should we look at more sustainable energy sources ?
Surely, because we're eating away at Earth's resources at a rate that can't be sustained by natural processes.
And we're burning off oil that could be put to far better uses.
Old 10-31-2010, 01:10 PM   #86 (permalink)
...beats walking...
Originally Posted by Rokeby View Post
I'd like to recognize, even applaud, all the members who have taken part in this discussion. You have provided information that each of us can pursue in trying to understand the legacy that we will leave to future generations. Well done, and thank you.
...so, does this mean that the 'collective' ecomodder audience have earned the accolades?:
"...plays well with others, inspite of running with scissors..."
"...only throws 'soft' rocks while playing within glass houses..."
"...willingly shares criticism with others, and sometimes even begrudgingly accepts it...
...sardonic, double entendre's, intended (wink,wink)!
Old 10-31-2010, 11:43 PM   #87 (permalink)
...(wink,wink)
Sounds a bit like the Acacademy Awards. Everybody gets to go home 'feeling good' about themselves...
Old 11-01-2010, 06:51 AM   #88 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
To paraphrase from The Incredibles, "Saying that everybody is special is just like saying that nobody is."
Old 11-01-2010, 08:30 AM   #89 (permalink)
Adding insulation (carbon dioxide) doesn't have instantaneous heating. You seem to think 150 years is a long time -- it is not.
How does the lowered albedo of the open water cause cooling? It doesn't. Methane is bubbling out of many lakes, bogs, and permafrost, and this will likely cause much greater warming.
It took millions and millions of years for all the carbon to get stored away under the ground, and the equilibrium of our climate has depended on the greenhouse gasses to stay within the range that it has for the entire recorded history of humans -- the last 10,000 years or so. Before that, it was a lot *colder* than it ever has been during recorded history.
We have released a large portion of those millions and millions of years of accumulated carbon in a blink of an eye -- most of it within just the last 50 years. How can we think that this would *not* affect the environment?
There are no general scientific questions about global climate change and the fact that humans are causing it is well established. The only questions are details about how fast the change will happen, and how much "momentum" there is in the system.
All indications are that the rate of warming and the "momentum" are outstripping even the most recent worse case scenarios.
We have passed the equilibrium threshold level of ~350ppm. Things will get worse before they get better. We have soiled our nest, and now we have to live with the consequences.
Why is it that this piece of science is questioned? Is it because it makes us uncomfortable, to admit that we humans have made a big mistake? That is the reason that some people question evolution. Evolution is totally settled science, and yet many people question it. Same for flat-earthers, and for those who believed that the Eaarth is the center of the solar system.
The scientific process of Global Climate Change is THE SAME as all other accepted science. If it is right on everything else, how can it be wrong on this?
Old 11-01-2010, 12:27 PM   #90 (permalink)
euromodder's Avatar
It's not just adding insulation.
We've kept the fire burning (the Sun) all the while.
Increasing the insulation and keeping the massive solar energy input should have driven up temps rather quickly considering the kind of atmospheric heating the sun can achieve daily.
There are immense questions about what is causing global climate changes.
It's far from certain CO2 is indeed driving that process.
How can scientists talk about an equilibrium, and fix a number for it, when it's not even certain wether CO2 is actually driving global warming ?
Evolution is questioned out of retarded religious beliefs.
Global warming is not questioned because of religious beliefs, it's questioned because the science and scientists behind the claims have been questionable - starting with the now infamous hockey-stick.
Anyone who went out to sea knew the earth wasn't flat.
They could all see it curving.
Likewise it has been known for ages before JC that the earth rotated around the sun.
It only became blasphemy later on when it was "well established" in temporary publications by a very influential publisher that everthing rotated around earth.
Like it has now become blasphemous to question human-induced, CO2 driven global warming.
