Go Back   EcoModder Forum > AltModding > Saving@Home
Old 11-13-2012, 07:21 AM   #1 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
eccoing house
I decided, now that the cold weather is approaching, that I am going to ecomod my house. The office extension is always cold in winter and hot in summer, its farthest from the furnace.I suspect they used less insulation during construction. I am going to start by installing another layer of fiberglass in the attic.
- Tony
Old 11-13-2012, 01:15 PM   #2 (permalink)
Yup, everything that applys to your car, applys to your home. Grill blocking the grills in the crawl spaces, smoothing over the windows with weather stripping and doors, putting a piece of insulation over the attic opening, insulation over and under your living spaces. A timer to cycle your hot water heater to the time when its most needed as well as turning down the temp on it. Setting your hvac for a lower temp and making sure the filter is clean.
One of my projects is to make a solar window heater.
Old 11-13-2012, 01:30 PM   #3 (permalink)
yup, started it last year when we purchased our place. First thing I did was put down an extra 6" of insulation (R-19) in the attic. A few weeks ago a insulated the attic access panel. Made it a system that has two layers of insulation to reflect the effective thickness of the rest of the attic.
Furance has a cold air intake, just changed the filter. A timer control on the water heater is a good idea. Or switch to one of those continuous water heaters, but I haven't checked on prices though.
Old 11-14-2012, 07:51 AM   #4 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
I would like to make a humidifier from the waste heat of the 85% afue furnace. I was looking on craigs list for insulation. Anyone have geothermal?
- Tony
Old 11-15-2012, 04:03 PM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Have you seen EcoRenovator's list of 60+ Home Energy Saving Tips You can do Right Now?
Old 11-23-2012, 10:45 AM   #6 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
I added a layer of r25 to the attic, it was harder than I thought getting to the corners. I found a piece of wall insulation, it looks like the stupids used R11 for the walls.
- Tony
Old 11-25-2012, 02:30 PM   #7 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
What's the best way to add insulation to exterior walls?
- Tony
Old 12-02-2012, 11:48 AM   #8 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
I had my exterior walls pumped full of insulation,2x4 walls = r13 I think it made a big diff. in the heating of my home, NOTE that put some 500 2-3 in holes on the inside ! I had a drywall man fill them and texture the walls for 500 bucks ,not too bad on cost. I also went with r38 ceiling insulation ca. required when you do a remodel. I have a raised foundation and will do the floor this winter cooler working conditions.
Old 12-30-2012, 12:09 PM   #9 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
I just finished putting cold air intake to the furnace. Taking intake air from the attic. The exhaust flue has a fan, so it doesn't rely on natural draft.
- Tony
Old 12-30-2012, 09:12 PM   #10 (permalink)
ron
get a filter on that attic makeup air and filter out all the sh-t ,depending on how old the house is you could have asbestos, rat,mouse sh-t alot of bad stuff
