Go Back   EcoModder Forum > AltModding > Saving@Home
Old 07-29-2016, 11:22 AM   #11 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I played with voltages in my PC a while back. My specs:
i5 3570K
Zotac Z77 ITX board
2x 4GB DDR3 @ 1.25v
mSATA Samsung 850 EVO SSD, 250GB
Radeon HD7850 2GB
Fortron 400w Platinum-rated power supply
Noctua NH-L9i cooler
I started with a full ATX motherboard, watercooling, and an 80+ rated 680w PSU. Sitting idle at the wall, the PC drew close to 100w at the wall, as measured by a Kill-a-Watt. After downsizing to a 380w power supply (Antec Earthwatts) and my Zotac ITX board, idle power consumption dropped to around 45w. I snagged the Fortron power supply for $25 (slickdeals) and further dropped idle power consumption to ~37w. The discrete video card, when on, is responsible for about 12w of that, meaning the PC sans gaming GPU draws approximately 25w.
I spent a while playing with voltages and frequency, to see the relationship with power consumption.
Starting off with a 4GHz overclock, I loaded it up with Prime95 and gradually lowered the voltage until I got instability. I found that I was able to reduce the total system power consumption with the CPU fully loaded (but not the GPU) from ~120w to ~95w by decreasing the CPU's operating voltage by 130mv.
This in turn reduced operating temperatures, and fan noise decreased.
Next, I plotted the minimum stable voltage vs frequency, after extensive trial and error.
Due to the voltage curve, CPU power consumption goes exponential as frequency increases. There seem to be two major inflection points, one at ~2800mhz and another at 4000mhz.
This is a graph of the power efficiency of the CPU when compared with frequency. I imagine it pretty closely resembles a BSFC vs load or RPM graph.
One would think then, that running the CPU as slowly as possible would be most efficient. This is actually not the case, at least if you're leaving the PC on 24/7 under load, doing work. Because the PC has certain fixed power consumption sources, when you factor those in, the extra time it takes to complete a task at lower frequency actually hurts efficiency.
The stock frequency Intel ships this CPU at is 3.4ghz, with turbo of up to 3.8ghz. For a system with slightly higher fixed power consumption, that stock frequency would be just about dead-center of the total system power efficiency peak.
If you're not running your PC 24/7 and relying on it to do the most calculations over time with the least energy, lowering CPU clockspeed is beneficial, to a point. I've backed off my clockspeed a bit, from 4ghz down to 3.8ghz, because I still appreciate the extra performance.
Some other areas where I have room for improvement:
-My 15 year old Z5500 (500w) speaker system draws 15w just plugged into the wall, and 35w when turned on but making no sound. I use these speakers on both mine and my wife's PC though, and they're wonderful for watching movies. I can't at present justify spending several hundred dollars to save <20w, so I'm likely to continue using them until they die.
-My 24" LCD screen is now 10 years old, and uses CFL backlighting. When on, it draws about 70w, whereas my wife's much newer 27" screen with LED backlighting draws about 35w. Here too, though, I can't justify spending several hundred dollars for the power consumption it saves.
Hope this is useful or interesting to someone!
freebeard (07-29-2016)
Old 07-29-2016, 01:32 PM   #12 (permalink)
NUC (Next Unit of Computing) makes my Mac Mini look big.
I still like the audio output stage on the Raspberry Pi; but another motherboard that comes to market in August is the Beagleboard AX-15:
Open source hardware (that's important). Official Specs:
  • Dual-core Sitara AM5728 ARM Cortex A15 @ 1.5Ghz
  • 750-MHz C66x DSP for analytics
  • Quad-core PRU for real-time control
  • Dual-core Cortex-M4 for even more real-time control
  • 4GB eMMC
  • 157 general purpose input/output (GPIO)
  • 20-pin ARM JTAG
  • eSATA
  • HDMI
  • 2 1Gb ethernet ports
  • 2GB DDR3L
  • µSD card slot
  • Micro USB 2.0 slave
  • 3 ports on a USB3.0 host
  • Audio in and out jacks
http://makezine.com/2015/10/14/beagleboard-officially-reveals-the-x15-and-its-a-beast/
Here's hoping the vacuum tube output stage on brass hex standoffs is available for it.
Xist (07-30-2016)
Old 10-05-2016, 11:43 PM   #13 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
Anyone know how to wire a car battery directly to the motherboard on one of these?? From what I understand they take 12v from the power supply so there shouldnt be too big an issue!! And then you can use a bike crank generator to make power for it will it's on and in use!!
Old 10-05-2016, 11:53 PM   #14 (permalink)
Not possible, with most motherboards. They also need 5v and 3.3v, as well as some negative rails. Also, 12.6v is asking for trouble, and if you tried to use a car's charging voltage of 14.2v, you'd fry it instantly.
EDIT: You really need a DC-DC converter, or a DC-AC and use the normal power plug.
Old 10-06-2016, 12:13 AM   #15 (permalink)
Looking into it you can get a resister setup to get the 5v and 3.3v from the 12v. At which point you'd need to find something to only supply 12v to the system!! If you could wire a car battery to the motherboard and used a 25 amp alternator you could possibly produce enough power to run it for 5 hours from one hour of peddling!!
Old 10-06-2016, 03:32 AM   #16 (permalink)
EchoTech
On most (all?) motherboards all the voltages are regulated. Using a resistor voltage divider the voltage will vary as the current draw varies and this variation can be quite large.
Old 10-06-2016, 03:47 AM   #17 (permalink)
90 day: 56.53 mpg (US)
Voltage regulators do not need to be expensive.
I've got one of these:
DC 3~40V to DC 1.5~35V Voltage Step Down Transformer Module 421830 2016
It does step down the power fairly efficiently.
On the con side, it will draw a few milliamps from the source even if no load is connected and it will draw a few milliamps from the output even if there is no input;
if you use it to charge a battery or such you need to disconnect it after charging or line it up with a diode. And you need a meter to set the correct output voltage.
Even so, a few bucks get you all the voltages you need (check the max current draw for each though)
Old 10-06-2016, 05:18 AM   #18 (permalink)
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
Hey guys, do it smart not hard. Google "12v tax psu" and you will fine the correct part.
Trying to save $ using resistors or home-brew regulators is a recipe to make BBQ motherboard for dinner.
There are times when trying to save money is counterproductive.
Simon
Old 10-06-2016, 07:19 AM   #19 (permalink)
... atx ...
But yes, using a small ATX is a good idea.
Old 10-06-2016, 07:30 AM   #20 (permalink)
Frigging Crapple autocorrect....
Simon
