Old 12-03-2017, 04:24 PM   #101 (permalink)
Master procastinator
Turan turan - '09 Volkswagen Touran Freestyle
Combot - '04 Opel Combo Tour
90 day: 40.37 mpg (US)
I reinstalled the top portion of the cover.
But it's only held on by two 10mm bolts, so it's easy to remove to inspect the belt and/or swap camshafts again.
Oh, ok.
I'll keep that trick with the cover in mind, might be handy sometime.
Old 12-03-2017, 06:46 PM   #102 (permalink)
90 day: 51.82 mpg (US)
So it WAS a cas of no-compression, briefly. All the lifters filledso the valves weren't closing fully?
Old 12-04-2017, 02:09 AM   #103 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Yup, that's how I understood it.
Mine took a long while to bleed down. I thought I had killed it!
The Following User Says Thank You to Stubby79 For This Useful Post:
MetroMPG (12-04-2017)
Old 12-04-2017, 03:52 PM   #104 (permalink)
Next mod...
Cardboard template made from the recently deceased fiberglass Kammback from the Firefly.
ID:	23112   Click image for larger version
Daox (12-04-2017)
Old 12-04-2017, 03:59 PM   #105 (permalink)
Looks pretty good (and familiar). How do you plan on finishing it this time? Fiberglass again?
The Following User Says Thank You to Daox For This Useful Post:
Xist (12-04-2017)
Old 12-04-2017, 04:51 PM   #106 (permalink)
Are you improving over the previous design, or is nine years good enough for you?
Old 12-04-2017, 05:51 PM   #107 (permalink)
Here you go, Frank! Validation on your rusty junk!
https://thegarage.jalopnik.com/heres...eer-1820250767
[His driver's side rusted far worse than the passenger's]
Old 12-04-2017, 06:25 PM   #108 (permalink)
Cut a row of 'speed holes' along the trailing edge to improve visibility?
Old 12-05-2017, 01:11 PM   #109 (permalink)
Visibility is actually OK - the horizon is visible in the mirror below the trailing edge.
As for construction, I'm aiming for quick 'n' dirty: Likely coroplast and aluminum tape. I may bend & attach a length of aluminum tube for strength and to support the trailing edge.
Nothing's so permanent as a temporary fix!
Ultimately, I was thinking metal riveted on for version 2. Sag-proof... though dentable. Trade-offs!
Old 12-05-2017, 03:56 PM   #110 (permalink)
TV antennae have a light-weight seamed aluminum tube. I have some samples.
You could make the whole thing out of that, just cut to length, smash the ends flat and drill it and pop-rivet it together. Maybe cover it with boat wrap? Like a WWI fighter fuselage?
