Old 06-26-2021, 05:14 PM   #41 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
As an eco freak I would tend more towards the Prius Prime before the RAV4 PRIME. It does have only 2,000lbs towing though and less leg room in the rear (but more in the front).
If there were a Camry Prime I'd get one of those. Or with just Camry vs. RAV4 non-prime I'd get the Camry. The Camry has more leg room front and rear and has better safety ratings. The RAV4 only has a 4 star overall NHTSA crash test rating but the Camry has a perfect 5 star rating. The Camry is also only about 50lbs lighter, so in the same weight category. The Camry also makes it onto the IISH's Top Safety Picks Plus list. The RAV4 barely makes it onto the Top Safety Picks list if you get it with certain headlights.
The Camry, however, has even less towing capacity (which is strange since it comes with the same engine and weighs pretty much the same). But still, I prefer leg room over head room. I'm more of a Lazy Boy kind of guy, not a kitchen chair kind of guy. That's what I love about my Avalon. I've been tortured sitting all day long in the rear of a RAV4 before. But I don't care who drives the Avalon, I'll have enough space in the rear even if I sit there.
Old 06-26-2021, 05:16 PM   #42 (permalink)
Porsche Cayenne diesel tows 7700 lbs. No serious issues but the factory service is ruinous every 5000 miles. Do it yourself...
Ours is 9 years old, still looks and runs great.
Old 06-26-2021, 05:55 PM   #43 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
Having a ~3000 lb trailer is a necessity for my wife's business. A lighter one likely would not have all the things that she needs.
Strangely enough, there was a Prius Prime at the dealership here. It looked nice, but there were two things I really hated about it: the horrible white interior and there was hardly enough room in the back for half a week's worth of groceries! Other than that, I am sure that it is a great car.
I suppose that the 2500 lb tow capacity on the Rav4 Prime is not really a limit then. I think I can just install a larger transmission cooler and be just fine with a 3000 lb trailer!
The Following User Says Thank You to Taylor95 For This Useful Post:
freebeard (06-26-2021)
Old 06-26-2021, 06:41 PM   #44 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.64 mpg (US)
Originally Posted by Autobahnschleicher View Post
The weirdest wheelbase to trailer ratio I've ever seen ws a Smart ForTwo towing a trailer with a glider inside it.
These trailers are almost 10 m long, it looked hillarious.
Note: That was *not* on public roads and you absolutely shouldn't do that.
Certainly my vehicle is a good bit larger than a ForTwo, but...
All I need is a slimp, and I'll be able to actually load it to capacity.
Usual disclaimer: amatuer driver, public roads, yada-yada.
The Following User Says Thank You to The Atomic Ass For This Useful Post:
Ecky (06-30-2021)
Old 06-26-2021, 06:50 PM   #45 (permalink)
As you can see from my pictures above, even un-modified, Toyota's HSD doesn't run into any cooling issues. Priinocchio now has over 300,000 miles.
Ecky (06-30-2021)
Old 06-26-2021, 07:29 PM   #46 (permalink)
I tow with my hybrid Avalon over 5,000 to 12,000ft passes and have no problems. Then again, I limit my towing loads to less than 1,500lbs.
Old 06-26-2021, 08:44 PM   #47 (permalink)
Supposedly the only relevant difference between the Rav4 Prime and the Rav4 TRD Adventure (tow capacity of 3500 lbs) is that the latter has a transmission cooler.
It's worth to remind the so-called e-CVT featured on many hybrids, such as the Toyotas with the HSD system, has a substantially different working principle in comparison to an actual CVT.
The Following 3 Users Say Thank You to cRiPpLe_rOoStEr For This Useful Post:
Hersbird (06-27-2021), Isaac Zachary (06-26-2021), Xist (07-29-2021)
Old 06-30-2021, 11:31 AM   #48 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by Noahfreak View Post
can tow with a good safety margin.
We don't believe in safety margins. Have you seen what half of our members tow here?? :P
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
Xist (07-29-2021)
Old 06-30-2021, 11:37 AM   #49 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Guilty as charged.
Old 06-30-2021, 12:12 PM   #50 (permalink)
I towed a piano this weekend. Does that count?
The Following User Says Thank You to Isaac Zachary For This Useful Post:
Ecky (06-30-2021)
