Old 09-27-2008, 10:20 PM   #1 (permalink)
jdub's Avatar
TDI Cup - '10 Volkswagen Jetta TDI Cup Street
90 day: 50.3 mpg (US)
Effect of surface temperature on attached flow
I have been wondering the last few days and so far I have been unsuccessful in finding any real information on whether or not an increase in surface temperature has a postive impact on attached flow.
For example, could it matter what color your car is? If your car is black and you live in a sunny climate, will the increased surface temperature of the car help reduce viscosity of the airflow over the car thus reducing drag? I realize at highway speed the cooling effect of the air over the surface will neutralize any solar heating, however in city driving could this make a difference?
Old 09-28-2008, 08:04 AM   #2 (permalink)
90 day: 51.82 mpg (US)
I haven't seen any "real" info on the topic, but I doubt there's any significant effect of the temp of the vehicle's surface on airflow simply because the passing air isn't in the vicinity long enough to change temperature.
aerohead (02-28-2011)
Old 09-28-2008, 08:14 AM   #3 (permalink)
Piaggio Fly 150 - '10 Piaggio Fly 150
90 day: 64.8 mpg (US)
I don't think the car's surface would affect it, but the local air temp would slightly vary the density of air which makes it harder/easier for the car to push through the air.
Check out my Green Cars Blog and the DIY electric car Wiki. Enjoy!
The Following User Says Thank You to mattW For This Useful Post:
Old 09-30-2008, 05:45 PM   #4 (permalink)
effect
I don't know of any investigation ever performed.I don't think it's an oversight.In the city,where it might have an effect,the speeds would be so slow as to lose any benefit.----------------- And as already mentioned,at higher speeds,the residence time of the air over the car is so brief,as to render the effect null.---------------------- My intuition tells me that this is probably a dead end,mpg wise.
Old 10-06-2008, 01:31 PM   #5 (permalink)
aerostatic
Blue - '04 Chevrolet Impala LS
90 day: 29.57 mpg (US)
If you have access to a introductory Heat Transfer textbook, you should be able to find out more information about this topic. Most hx books contain at least baisc info about it and may direct you to further reading. Your local library may not have them, but should be able to order them on inter-library loan. Heated surfaces would have some positive effect but on ordinary vehicles the difference wouldn't be enough to notice because the points of separation are very distinctly due to geometry. ie behind the rear-view windows and cabin.
I'm sure if results were to be taken in the lab, positive results could be recorded for shapes that are more aerodynamic which do not regularly experience flow separation but my guess is that positive results would be obtained only at higher temps than would occur from solar heating.
Old 02-25-2011, 12:23 AM   #6 (permalink)
if the surface temperature is increase, we heat the surface and insulate from inside, so that the passenger won't feel hot?
does this decrease the drag?
Old 02-25-2011, 12:40 AM   #7 (permalink)
Sure! Snow and ice melt off black vehicles sooner and more completely, so that makes 'em sleeker.
Old 02-25-2011, 09:03 AM   #8 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
I have not been here long, but I do get a giggle when Frank gives one of his 'short and sweet' answers.
Old 02-25-2011, 03:49 PM   #9 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
NACA did some tests and the results in drag were not all too great.
EDIT: I meant to state that they had little effect
http://ntrs.nasa.gov/archive/nasa/ca...1979070772.pdf
Old 02-25-2011, 09:00 PM   #10 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Colder air is denser and has less viscosity, therefore would remain attached longer in adverse pressure gradients and have a thinner boundary layer. I think that a cold surface would have less drag for body dominated by surface drag and not much effect on a blunt body like a car.
- Tony
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Stock Temperature Gauges jcantara Instrumentation 24 05-26-2010 11:26 PM
mods-data-%change Cd or drag(installment#3 surface drag) aerohead Aerodynamics 6 06-03-2008 06:10 PM
Smooth Road Effect newtonsfirstlaw General Efficiency Discussion 7 01-16-2008 05:37 PM
