Old 02-26-2011, 08:58 AM   #11 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Originally Posted by BHarvey View Post
I have not been here long, but I do get a giggle when Frank gives one of his 'short and sweet' answers.
me too
Old 02-28-2011, 05:24 PM   #12 (permalink)
noodling
If you wanted to do some noodling,consider that a Mazda Miata-sized car will displace 93,456 cubic feet of air/mile.
At your design urban velocity you could figure your CFM.
The CRC Manual of Tables would have the albido for different colors.
An ASHRAE Manual would have the solar insolation/per square foot falling on the car.
The ASRAE manual will also have a psychrometric chart with which you could compare enthalpies/densities/etc. to see what air density differentials could be generated for a given heat flux generated per color on the car.
With that you could plug into the aero drag equation and look at your differences.
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Stock Temperature Gauges jcantara Instrumentation 24 05-26-2010 11:26 PM
mods-data-%change Cd or drag(installment#3 surface drag) aerohead Aerodynamics 6 06-03-2008 06:10 PM
Smooth Road Effect newtonsfirstlaw General Efficiency Discussion 7 01-16-2008 05:37 PM
